    PanelDue 5 blurry rows
    PanelDue
    347
    • cdthomas9undefined
      cdthomas9
      I have a PanelDue 5 (not 5i) connected to a Duet 2. I get a weird smudging or blurriness a little more than halfway down the panel. It seems to be right around the row where the current XYZ position is shown. I did notice that this appeared in the splash screen, before I flashed the other version of firmware.
      T3P3Tonyundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
      • A Former User?
        A Former User
        i reckon its likely physical damage to panel or connection through to the paneldue. pictures of the back with better lighting and focus may be helpful
        • T3P3Tonyundefined
          T3P3Tony administrators @cdthomas9
          @cdthomas9 is this new (I assume so with the new 6HC?) If so then it looks to be a warranty replacement, especially if the blurriness follows when you switch to other tabs.
          www.duet3d.com
            cdthomas9
            It is new, but ordered from overseas with a board in a bundle. This blurriness persists in all things displayed on the screen. I didn't see anything on the back of the screen when I was installing it, but I wasn't really looking for it either. Just glancing over it to make sure it looked OK.
            droftartsundefined A Former User? 2 Replies Last reply Reply Quote 0
              droftarts administrators @cdthomas9
              @cdthomas9 If it came in the bundle with the clone Duet 2 WiFi as shown in your other thread https://forum.duet3d.com/post/172269 then it's a clone PanelDue, as well. For any issues with this hardware, you need to take it up with whoever you bought it from. We don't/can't support any products that we didn't manufacture.
                cdthomas9
                OK, thanks for the assistance. I'll see if I can tell if it is an original or not, is there an easy way to tell?
                • T3P3Tonyundefined
                  @cdthomas9 the easiest way is to see if the seller is a genuine Duet reseller:
                  https://www.duet3d.com/GenuineResellers
                  www.duet3d.com
                    Phaedrux Moderator @cdthomas9
                    @cdthomas9 said in PanelDue 5 blurry rows:
                    PanelDue 5 (not 5i)
                    Also I don't think the non-i version of PanelDue has been in official channels for quite some time.
                    • A Former User?
                      A Former User @cdthomas9
                      someone else might spot something relevant, thats kinda why I suggested uploading some pictures; but beyond the long shot below I think you'll be looking at repairs or replacement
                      a gentle massage to panel and interconnects may resolve issues with the panel or pin point where any issues with interconnections are. esd and short circuit precautions left and right should apply.
                        cdthomas9
                        Thanks everyone for your help. I looked for the non i version specifically since it would fit the casing I had found. I'll check into the dimensions on the 5i, I might be able to swap it out and still use the case. I'll get a real one this time if it will work. Otherwise I might just run with it for a while if I can't get the vendor to replace it. Thanks again for all of your help guys!
                          dc42 administrators @cdthomas9
                          Although I'd love you to buy a genuine PanelDue, IMO the vendor should replace the display panel. If the vendor won't, you could buy just a new display panel. There is a section in https://miscsolutions.wordpress.com/paneldue/ about compatible displays.
                            cdthomas9
                            OK, thanks! I'll keep that in mind in case I have problems with a resolution
