Duet Wifi V2 Upgrade to 3.1.1 - Wifi not working
After upgrading from 2.04 to 3.0.0 to 3.1.1, my ip address no longer shows up in the console. Running M552 command shows that "WiFi module is being started". The led on the wifi module is a solid blue and no status change after that.
M552 S0 does not do anything and M552 S1 "NetworkName" tells me to "Turn off the current WiFi mode before selecting a new one.
Any help would be great. Thanks in advance!
Did you also update the wifi server firmware to 1.23? Might need a USB terminal to get a M122 result to check the version.
You can try reflashing the wifi server as well.
What do you have in your config.g?
Tried M997 S0:1:2 to update all firmwares
M122 command
Tried M552 S-1, M552 S1, then M552. Just keeps showing "WiFi module is being started
config.g (If you see any other issues, please let me know)
; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Aug 10 2020 22:27:49 GMT-0600 (Mountain Daylight Time); General preferences
M550 P"Kossel" ; set printer name
M665 R220 L385 B130 H140 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; set minimum Z; Endstops
M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z2 S1 P"zstop" ; configure Z-probe endstop for low end on Z; Z-Probe
G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 R85 S20 ; define mesh grid; Heaters
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@Phaedrux I flashed with wifi server firmware associated with 3.1.1. Not sure what version it is and looking at M122 output doesn't tell me the version
@Phaedrux Wifi server was working prior to the upgrade so not sure what happened
@Dataro81 said in Duet Wifi V2 Upgrade to 3.1.1 - Wifi not working:
It's at the bottom in the wifi section, but if it says wifi disabled, it may not show anything else.
When you flashed DuetWiFiServer.bin from the 3.1.1 zip file, did it give any indication that it flashed successfully?
@Phaedrux Yeap, let me run M997 S0:1:2 again and attach what i see
@Phaedrux Do you know what the syntax is to just update the webserver firmware?
@Phaedrux nm found the info. M997 S1
M997 S1 will do wifi server only
https://duet3d.dozuki.com/Wiki/Gcode#Section_M997_Perform_in_application_firmware_update
@Phaedrux Thanks! Updating the webserver firmware singularly fixed the issue!
Glad that worked.
