Extruder fan permanently spinning
Can someone help, my extruded fan (not part fan) just spins all the time despite the fact that it should be controlled by the thermostat. No doubt there is something amiss with my config.
Here it is
; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Aug 12 2020 12:40:08 GMT+0100 (British Summer Time); General preferences
M550 P"CoreXY" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M584 X1 Y0 Z2 E3 ; set drive mapping
M92 X100.00 Y100.00 Z400.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M906 X700 Y700 Z600 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X280 Y280 Z300 S0 ; set axis maxima; Endstops
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M558 P9 C"^zprobe.in" H3 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M106 P1 S0 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M563 P0 D0 H1 F0:1 ; define tool 0
If I swap the fan from "fan1" to "fan2" then it works as expected. It seems that "fan1" is permanently outputting 24v no matter what I do to it.
@StevePS3 It could be that the fan1 Mosfet has failed open. Can you take a good, high resolution picture of your Duet, of the area around the fan1 connection? Looking for failed components.
I've tried to but I keep getting "Something went wrong whilst processing server response"
@StevePS3 said in Extruder fan permanently spinning:
What browser are you using? I think this happens sometimes with Chrome.
I can't see anything obviously wrong with the MOSFET.
Ahh yes, Chrome.
No, they looked OK to me.
M563 P0 D0 H1 F0:1 ; define tool 0Where do you have your fans actually connected?
Your tool has defined fan0 and fan1 as the tool fan. If fan1 is the hotend heatsink fan, then you don't want fan1 assigned to the tool as well.
Change
M563 P0 D0 H1 F0:1
to beM563 P0 D0 H1 F0
