    Bltouch Setup Issue
    • Dataro81undefined
      Dataro81
      Trying to get my bltouch setup on my duet 2 wifi (firmware 3.1.1) for my delta printer. I was able to get the probe to deploy and retract, but the hotend crashes into the bed when the probe is deployed. Probe value stays 0 no matter if retracted or deployed.
      Attaching wiring, config.g, and calibration and compensate gcode below.
      Calibrate and Compensate
      G28 ; home
      M104 S0 ; turn off hot end
      M140 S0 ; turn off bed
      M280 P0 S10 ; deploy BLTouch
      G32 ; auto calibrate
      G29 ; generate bed height map
      G28 ; home
      M280 P0 S90 ; retract BLTouch
      config.g
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Aug 10 2020 22:27:49 GMT-0600 (Mountain Daylight Time)
      M550 P"Sandoria Kossel" ; set printer name
      M665 R220 L385 B130 H140 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; set minimum Z
      M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
      M574 Z2 S1 P"zstop" ; configure Z-probe endstop for low end on Z
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 R85 S20 ; define mesh grid
      ![1_1597253175153_IMG_3976.jpeg](Uploading 100%) ![0_1597253175152_IMG_3975.jpeg](Uploading 100%) IMG_3975.jpeg
      Kolbiundefined 1 Reply Last reply Reply Quote 0
      • Kolbiundefined
        Kolbi @Dataro81
        @Dataro81 It's hard to see, but I think I only see one pin between the ground wire and the heater3 wire on your pic - should be 2 pins in-between.
        Dataro81undefined 1 Reply Last reply Reply Quote 0
        • Dataro81undefined
          Dataro81 @Kolbi
          @Kolbi Hi, I have two pins in between. Do my configs look correct?
            Config looks ok, except
            G31 P500 X0 Y0 Z2.5
            Change P500 to P25, and measure your X Y Z offset.
            https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
            For the failure to trigger problem that would indicate an issue with your white wire. Check continuity.
            Dataro81undefined 2 Replies Last reply Reply Quote 0
            • Dataro81undefined
              Dataro81 @Phaedrux
              Thanks @Phaedrux . Will go through your suggestions later today. Back to back meetings all day...
              • Dataro81undefined
                Dataro81 @Phaedrux
                @Phaedrux Woot! The code change fixed my issue! Had to lower my bltouch a little so the hotend didn't hit the bed first, but other than that it worked like a charm. Thanks for all the help today!!
