    Extruder not recognized.
    • stuartofmt
      stuartofmt last edited by
      I just upgraded to RRF3 and most everything seems to be working so far.
      I cannot get the extruder controls to show up in the web interface - it is greyed out. I have preheated the nozzle to 160 and also tried to issue a M302 P1 but that does not help either.
      Connector for the extruder is plugged into second connection (i.e. one immediately before X). I also tried it connected to E0 and with appropriate adjustments to config.g - no change.
      Any and all help appreciated.
      Versions:
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
      Duet WiFi Server Version: 1.23
      config.g
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Aug 13 2020 14:00:14 GMT-0600 (Mountain Daylight Time)
      G90                                            ; send absolute coordinates...
      M83                                            ; ...but relative extruder moves
      M550 P"Ender 5Pro BLT"                         ; set printer name
      M552 S1                                        ; enable network
      M586 P0 S1                                     ; enable HTTP
      M586 P1 S0                                     ; disable FTP
      M586 P2 S1                                     ; enable Telnet
      M569 P0 S1                                     ; physical drive 0 goes forwards
      M569 P1 S1                                     ; physical drive 1 goes forwards
      M569 P2 S0                                     ; physical drive 2 goes backwards
      M569 P3 S0                                     ; physical drive 3 goes backwards
      M584 X0 Y1 Z2 E3                               ; set drive mapping
      M350 X64 Y64 Z64 E64 I0                        ; configure microstepping without interpolation
      M92 X320.00 Y320.00 Z3200.00 E320.00           ; set steps per mm
      M566 X1200.00 Y1200.00 Z24.00 E300.00          ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z3000.00 E900.00        ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z250.00 E250.00           ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I50                   ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                        ; Set idle timeout
      M208 X0 Y0 Z0 S1                               ; set axis minima
      M208 X220 Y220 Z300 S0                         ; set axis maxima
      M574 X1 S1 P"xstop"                            ; configure active-high endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                            ; configure active-high endstop for low end on Y via pin ystop
      M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
      M950 S0 C"exp.heater3"                         ; create servo pin 0 for BLTouch
      M558 P9 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X42 Y5 Z2.48                          ; set Z probe trigger value, offset and trigger height
      M557 X5:210 Y5:210 S20                         ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
      M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                        ; map heated bed to heater 0
      M143 H0 S80                                    ; set temperature limit for heater 0 to 80C
      M308 S1 P"e0temp" Y"thermistor" T100000 B4092  ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
      M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H1 T45                              ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500                           ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H-1                                 ; set fan 2 value. Thermostatic control is turned off
      M563 P0 S"Nozzle" H1 F0                        ; define tool 0
      G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
      G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
      M501                                           ; load saved parameters from non-volatile memory
      config-override.g only had pid settings (but a lot of repeated G10's
      ; config-override.g file generated in response to M500 at 2020-08-13 13:34
      ; Heater model parameters
      M307 H0 A154.4 C486.6 D0.9 S1.00 V24.0 B0
      M307 H1 A357.4 C117.5 D3.9 S1.00 V24.1 B0
      ; Workplace coordinates
      G10 L2 P1 X0.00 Y0.00 Z0.00
      G10 L2 P2 X0.00 Y0.00 Z0.00
      G10 L2 P3 X0.00 Y0.00 Z0.00
      G10 L2 P4 X0.00 Y0.00 Z0.00
      G10 L2 P5 X0.00 Y0.00 Z0.00
      G10 L2 P6 X0.00 Y0.00 Z0.00
      G10 L2 P7 X0.00 Y0.00 Z0.00
      G10 L2 P8 X0.00 Y0.00 Z0.00
      G10 L2 P9 X0.00 Y0.00 Z0.00
      • droftarts
        droftarts administrators @stuartofmt last edited by
        @stuartofmt said in Extruder not recognized.:
        You don’t have an extruder drive assigned to your tool. Add ‘D0’.
        • stuartofmt
          That did the trick - THANKS!
          I'm using the configuration tool and obviously lacking a comprehension of some of the concepts.
