    Ayuda core xy con duet2wifi
    3.0k
    • Fabiánundefined
      Fabián
        droftarts administrators @Fabián
        @Fabián looks good. Does it show correctly on PanelDue and DWC now?
        • Fabiánundefined
          Fabián
          no sigue siendo desigual Ian
          • Fabiánundefined
            Fabián
            Ian acabo de pedir una duet2wifi original a DUET y una Placa PT100,
            • Fabiánundefined
              Fabián
                @Fabián -273 usually means disconnected, 2000C means short circuit. If you have a PT100 fitted instead of the Semitec thermistor, it does have very low resistance, and would read high.
                But it’s strange this shows on the PanelDue and not on DWC. What version DWC is this? Go to System > General.
                Also, please take a picture of your Duet and wiring, and show where you have plugged in bed thermistor and hot end thermistor.
                Another way to test temperature readings is to connect a 100k ohm resistor in place of your thermistor. You can do this direct on the board. With your settings, it should read 25C.
                • Fabiánundefined
                  Fabián
                  IMG_20200819_213340.jpg IMG_20200819_213416.jpg IMG_20200819_213349.jpg IMG_20200819_213408.jpg
                  • Fabiánundefined
                    Fabián
                    Probando directamente con una resistencia de 100K marca en los 2 paneles lo mismo no varia , mido con el fluke la resistencia del termistor de la cama mide 97,6 K, y la resistencia del termistor del hotend 98,7 K
                      @Fabián Hmm... very strange! I can’t see anything obviously wrong. Does M308 S0 and M308 S1 still report correctly?
                      The only thing that has been similar to this in the past is a bad firmware update. Please could you try downloading a fresh Duet2CombinedFirmware.bin file from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.1.1 upload to your Duet, and run M997 S0 to reflash the firmware.
                      • Fabiánundefined
                        Fabián
                        ok lo hago ahora mismo y te informo
                        • Fabiánundefined
                          Fabián
                          @droftarts said in Ayuda core xy con duet2wifi:
                          M997 S0
                          acabo de actualizar y sigue igual Ian
                            Check your wiring.
                            • Fabiánundefined
                              Fabián
                              Hola Ian ,
                              Despues de haberme quedado hasta las 04.00 am , revisando todo el cableado y comprobando la duet fuera de la maquina , estaba todo correcto conectado no habia ningun cortocircuito y los termistores estaban bien , es todo nuevo , leyendo en el foro vi esto de config en sys
                              ; Calentadores
                              M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; Configurar el sensor 0 como termistor en el pin bedtemp
                              M950 H0 C"bedheat" T0 ; Crear la salida del calentador de la cama en el calentador de la cama y asignarlo al sensor 0
                              M143 H0 S150 ; Establecer el límite de temperatura para el calentador de 0 a 150C
                              M307 H0 B0 S1.00 ; Habilitar el modo bang-bang para el calentador de cama y establecer el límite PWM
                              M570 H0 P30 T15 S0 ; Configurar la detección de fallas del calentador
                              M140 H0 ; Mapa cama calefactora a calefactor 0
                              M308 S1 P"e0temp" Y"thermistor" R4700 T100000 B3950 ; Configurar el sensor 1 como termistor en el pin e0temp
                              M950 H1 C"e0heat" T1 ; Crear la salida del calentador de la boquilla en e0heat y asignarla al sensor 1
                              M143 H1 S300 ; Establecer el límite de temperatura para el calentador de 1 a 350C
                              M307 H1 B0 S1.00 ; Deshabilitar el modo bang-bang para el calentador y establecer el límite PWM
                              Y todo ya marca temperatura correcta en el panel due y en el Gui
                              Que mas pasos he de hacer para comenzar a imprimir , y que el hotend se acerque a la superficie de la cama, como calibro esto ?
                              Phaedruxundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                Phaedrux Moderator @Fabián
                                @Fabián said in Ayuda core xy con duet2wifi:
                                And everything already marks the correct temperature in the due panel and in the Gui
                                What more steps do I have to do to start printing, and get the hotend closer to the surface of the bed, how do I calibrate this?
                                Sounds like your temperatures are displaying correctly now.
                                To start printing you'd need to set up your slicer and upload the gcode file in the web interface.
                                To get the hot end closer you may need to calibrate your z probe.
                                https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                                  @Fabián was it adding the M570 command that fixed this? And one for heater 1? I did notice in your M308 command response that it said “ last error: sensor not ready” and meant to ask @dc42 what this would mean. I expect it takes the clone board (often made with 1oz copper rather than 2oz) extra time to get a consistent reading from the thermistors, otherwise it reports a fault. Can you link the original thread where you found this information?
                                  Hopefully this won’t be an issue with your genuine Duet!
                                  • Fabiánundefined
                                    Fabián
                                    Hola Ian,
                                    Esto copie de un usuaio del foro realmente no recuerdo su nombre , pero si copie su configuracion que es esta:
                                    ; Fichero de configuración para el Duet WiFi (firmware versión 3.1.1)
                                    ; Ejecutado por el firmware en el arranque
                                    G90 ; Enviar coordenadas absolutas...
                                    M83 ; ...pero el extrusor relativo se mueve
                                    M550 P"IDEX" ; Establecer el nombre de la impresora
                                    M552 S1 ; Enable network
                                    M586 P0 S1 ; Enable HTTP
                                    M586 P1 S0 ; Disable FTP
                                    M586 P2 S0 ; Disable Telnet
                                    ; Controladores
                                    M569 P0 S1 ; El impulso físico X va hacia Snnn: 0 = hacia atrás, 1 = hacia adelante
                                    M569 P1 S0 ; El impulso físico Y va hacia Snnn: 0 = hacia atrás, 1 = hacia adelante
                                    M569 P2 S1 ; El impulso físico Z va hacia Snnn: 0 = hacia atrás, 1 = hacia adelante
                                    M569 P3 S0 ; El impulso físico E0 va hacia Snnn: 0 = hacia atrás, 1 = hacia adelante
                                    M569 P4 S1 ; El impulso físico E1 va hacia Snnn: 0 = hacia atrás, 1 = hacia adelante
                                    M569 P5 S1 ; El impulso físico U va hacia Snnn: 0 = hacia atrás, 1 = hacia adelante
                                    M584 X0 Y1 Z2 U5 E3:4 ; Establecer el mapeo de la unidad de disco
                                    M350 Z32 I0 ; Configurar los micro-pasos sin interpolación
                                    M350 X16 Y16 U16 E16 I1 ; Configurar los micro-pasos con interpolación
                                    M92 X100.00 Y100.00 Z800.00 U100 E150.00:150.00 ; Establecer pasos por mm
                                    M566 X900.00 Y900.00 Z12.00 U900.00 E8000.00:8000.00 ; Establecer los máximos cambios de velocidad instantánea (mm/min)
                                    M203 X9000.00 Y9000.00 Z3000.00 U9000.00 E9000.00:9000.00 ; Establecer las velocidades máximas (mm/min)
                                    M201 X1800.00 Y1800.00 Z24.00 U1800.00 E8000.00:8000.00 ; Establecer las aceleraciones (mm/s^2)
                                    M906 X320 Y1360 Z320 U320 E1360:1360 I30 ; Establecer las corrientes del motor (mA) y el factor de ralentí del motor en porcentaje
                                    M84 S60 ; Establecer el tiempo de espera para desactivar motores
                                    ; Límites del eje
                                    M208 X0 Y0 Z0 U60 S1 ; Establecer los mínimos del eje
                                    M208 X240 Y220 Z200 U300 S0 ; Establecer los máximos de los ejes
                                    ; Finales de carrera
                                    M574 X1 S1 P"xstop" ; Configurar activo-alto para el extremo inferior en X a través del pin xstop
                                    M574 Y1 S1 P"ystop" ; Configurar activo-alto para el extremo inferior en Y a través del pin ystop
                                    M574 Z1 S1 P"zstop" ; Configurar activo-alto para el extremo inferior en Z a través del pin zstop
                                    M574 U2 S1 P"duex.e2stop" ; Configurar activo-alto para el extremo inferior en U a través del pin e0stop
                                    M950 J1 C"e0stop" ; Configura la entrada 1 usa el pin e0stop
                                    M950 J2 C"duex.e3stop" ; Configura la entrada 1 usa el pin duex.e2stop
                                    M581 P1 T2 R1 ; Configurar disparador externo Tnn: 0= M112, 1= M25, >1(#) = se ejecute el archivo macro sys / trigger#.g.
                                    M581 P2 T3 R1 ; Configurar disparador externo Tnn: 0= M112, 1= M25, >1(#) = se ejecute el archivo macro sys / trigger#.g.
                                    ;NOTA: Complemente en el Star-code (M582 T#; Chequea si hay presencia de filamento)
                                    ; Sonda Z
                                    M558 P0 H5 F120 T6000 ; Desactivar la sonda Z pero ajustar la altura de inmersión, la velocidad de la sonda y la velocidad de desplazamiento
                                    M557 X15:215 Y15:195 S20 ; Definir la red de malla
                                    ; Calentadores
                                    M308 S2 P"e1temp" Y"thermistor" R4700 T100000 B3950 ; Configurar el sensor 2 como termistor en el pin e1temp
                                    M950 H2 C"e1heat" T2 ; Crear la salida del calentador de la boquilla en e1heat y asignarla al sensor 2
                                    M143 H2 S300 ; Establecer el límite de temperatura para el calentador de 2 a 350C
                                    M307 H2 B0 S1.00 ; Deshabilitar el modo bang-bang para el calentador y establecer el límite PWM
                                    M302 P0 S160 R160 ; Pnnn Estado de permiso, Snnn Temp. mín. extrusión, Rnnn Temp. mín. retracción
                                    ; Ventiladores
                                    M950 F0 C"fan0" Q500 T1 ; Crear el ventilador 0 en el pin fan0 y establecer su frecuencia
                                    M106 P0 C"Frontal_1" S1 H1 T45 ; Ponga el nombre y el valor del ventilador 0. El control termostático está activado
                                    M950 F1 C"fan1" Q500 ; Crear el ventilador 1 en la clavija fan1 y establecer su frecuencia
                                    M106 P1 C"Ventilador_1" S0 H-1 ; Ajustar el valor del ventilador 1. El control termostático está apagado
                                    M950 F2 C"fan2" Q500 ; Crea la salida fan2 para la tira LED a 500Hz
                                    M106 P2 C"LED" S255 ; Activa el ventilador a 255
                                    M950 F3 C"duex.fan3" Q500 T2 ; Crear el ventilador 0 en el pin fan0 y establecer su frecuencia
                                    M106 P3 C"Frontal_2" S1 H2 T45 ; Ponga el nombre y el valor del ventilador 0. El control termostático está activado
                                    M950 F4 C"duex.fan4" Q500 ; Crear el ventilador 1 en la clavija fan1 y establecer su frecuencia
                                    M106 P4 C"Ventilador_2" S0 H-1 ; Ajustar el valor del ventilador 1. El control termostático está apagado
                                    ; Herramientas
                                    M563 P0 S"DART1" D0 H1 F0:1 ; P = Definir la herramienta 0, D = Extrusora 0, H = Calentador 1, F = Ventilador 0 y 1
                                    M563 P1 S"DART2" D1 H2 X3 F3:4 ; P = Definir la herramienta 1, D = Extrusora 1, H = Calentador 2, F = Ventilador 3 y 4
                                    M563 P2 S"DART12" D0:1 H1:2 X0:3 F0:1:3:4 ; Cree una herramienta que imprima 2 copias del objeto usando ambos carros
                                    G10 P0 X0 Y0 U0 Z0 ; Establecer la herramienta 0 desplazamientos del eje
                                    G10 P1 Y-0.05 U-0.25 Z0 ;MODIFICA U e Y si es necesario ; Establecer la herramienta 1 desplazamientos del eje
                                    G10 P2 X0 Y0 U-150 ; Establecer la herramienta 2 desplazamientos del eje
                                    G10 P0 R0 S0 ; Establecer la herramienta inicial 0 activa y las temperaturas de espera a 0C
                                    G10 P1 R0 S0 ; Establecer la herramienta inicial 1 activa y las temperaturas de espera a 0C
                                    G10 P2 R0 S0 ; Establecer la herramienta inicial 2 activa y las temperaturas de espera a 0C
                                    ; LCD
                                    M575 P1 S1 B57600 ; Establecer parámetros de comunicación serie
                                    ; Siempre al final
                                    M912 P0 S-4 ; Corrije la temperatura de la CPU
                                    M501 ; Lee parámetros almacenados. Establezce los parámetros activos a los almacenados en sys / config-override.g en la tarjeta SD
                                    M911 S22 R23 P"M913 X0 Y0 Z0 E0" ; Configure el guardado automático en la pérdida de energía
                                    T0 P0 ; Seleccion de herramienta por defecto
                                    Yo hoy recibo mi duet original, y puedo poner mi ultima config sys , ocrees que tendré problemas ?
                                      Hopefully you won’t have problems with the new board. Did you change the thermistor settings so they are correct for the thermistors you have?
                                      • Fabiánundefined
                                        Fabián
                                        Hola Ian de nuevo,
                                        Acabo de poner en marcha la duet ORIGINAL , no obtuve conexion wifi con ella , entonces actualice al rpp3 3.1.1 con BOSSA y ok.
                                        Conecto con el YAT envio M115 : esta actualizada a 3.1.1 y 1.02 wifi , intento conectar a la red wifi siguiendo las intrucciones y salen errores de wifi , el led azul no enciende
                                        • Fabiánundefined
                                          Fabián
                                          Funciona todo correctamente termistores lecturas de Temperatura , temperatura CPU ventiladores , hotend , cama Ok
                                          Lo unico que no hay manera de conectar por wifi a la web
                                          • Fabiánundefined
                                            Fabián
                                            repeti los pasos de configuracion , pero no hace nada , solo parpadea al poner en marcha 1 vez y ya
