short-to-ground reported by driver 0 1 2 4. Help Needed
  • I am new to the Duet board but have been building CNC machines for a while. This is a new install of a Duet 3 6HC on a newly created printer.
    Whenever I try any motion the short-to-ground error is given. I have tripple checked all the wiring, tested the motors and wires on other systems and also used a meter to check/verify the wiring and coils in the motors. There is no short in the wires or motors.
    I am at a loss. I have searched forum and found others with similar errors but they usually had wiring issues. I don't all the motors work, tested individually on the good driver channels.
    Here is my configuration file and a list of the errors.
    ; --------------- Pin/connection Mapping Legend -------------------
    ; out0 - UNUSED
    ; out1 - Extruder 1 heater
    ; out2
    ; out3
    ; out4
    ; out5
    ; out6
    ; out7 - Solid State Relay 1 (Bed Heater)
    ; out8 - Solid State Relay 2 (unused)
    ; out9 - Run Signal to Limits/E-Stop board.
    ; out4.tach
    ; out5.tach
    ; out6.tach
    ; io0.in - X limit switch. Active High Signal.
    ; io1.in - Y limit switch. Active High Signal.
    ; io2.in - Z limit switch. Active High Signal.
    ; io3.in - Emergency stop from Limits/E-Stop board.
    ; io4.in - Unused Signal from Limits/E-Stop board.
    ; io5.in
    ; io6.in
    ; io7.in - BL-Touch
    ; io8.in
    ; io0.out
    ; io1.out
    ; io2.out
    ; io3.out
    ; io4.out
    ; io5.out
    ; io6.out
    ; io7.out - BL-Touch
    ; io8.out
    ; pson
    ; spi.cs0
    ; spi.cs1
    ; spi.cs2
    ; spi.cs3
    ; temp0 - Bed Thermistor
    ; temp1 - Hotend Thermistor
    ; temp2
    ; temp3
    ; mcu-temp - MCU sensor
    ; driver0 - XY Left NEMA 23 Stepper 4.0 Amps, 20 tooth GT2 belt.
    ; driver1 - XY Right NEMA 23 Stepper 4.0 Amps, 20 tooth GT2 belt.
    ; driver2 - Z Center/Rear NEMA 17 Stepper 1.5 Amps, Belt drive 3:1 reduction driving 1204 ballscrew.
    ; driver3 - Z Left/Front NEMA 17 Stepper 1.5 Amps, Belt drive 3:1 reduction driving 1204 ballscrew.
    ; driver4 - Z Right/Front NEMA 17 Stepper 1.5 Amps, Belt drive 3:1 reduction driving 1204 ballscrew.
    ; driver5 - Extruder, NEMA 17 Stepper 1.3 Amps, 14:1 planetary geared, driving Bondtech Drivegear 35mm/rotation
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Fri Aug 14 2020 15:56:18 GMT-0400 (Eastern Daylight Time)
    G04 P2000 ; Pause for 2 seconds.
    M550 P"Duet 3" ; set printer name
    G21 ; Set units to Millimeters.
    M669 K1 ; select CoreXY mode
    M569 P0.1 S1 ; physical drive 0.1 goes forwards
    M569 P0.2 S1 ; physical drive 0.2 goes forwards
    M569 P0.3 S0 ; physical drive 0.3 goes forwards
    M569 P0.4 S1 ; physical drive 0.4 goes forwards
    M569 P0.5 S1 ; physical drive 0.5 goes forwards
    ; Next Line Modified.
    M584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5 ; set drive mapping. 3 Z motors
    ; Next Line Modified. Uncomment and update when data is known.
    ; Set up three Z-axis location
    ;M671 X-52.5:377.5:377.5 Y162.5:282.5:42.5 S5 ; leadscrews at 1 - left, 2 - rear right and 3 - front right
    M92 X80.00 Y80.00 Z2400.00 E420.00 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z600.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X3000 Y3000 Z1000 E800 I50 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X230 Y210 Z200 S0 ; set axis maxima
    M574 X1 S1 P"io0.in" ; configure active-high endstop for low end on X via pin io0.in
    M574 Y1 S1 P"io1.in" ; configure active-high endstop for low end on Y via pin io1.in
    M574 Z1 S1 P"io2.in" ; configure active-high endstop for low end on Z via pin io2.in
    M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
    M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X0 Y32 Z2.5 ; set Z probe trigger value, offset and trigger height
    M557 X15:215 Y15:195 S20 ; define mesh grid
    M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
    M950 H0 C"out7" T0 ; create bed heater output on out7 and map it to sensor 0
    M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
    M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
    M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
    M950 F1 C"out5" Q500 ; create fan 1 on pin out5 and set its frequency
    M950 F2 C"out6" Q500 ; create fan 2 on pin out6 and set its frequency
    M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on
    ; Emergency Stop
    M574 S1 P"^!io3.in" ; Define Emergency endstop - emergency stop switch condition
    M581 P"io3.in" T0 ; Define action to be taken with activation of emergency stop switch
    T0 ; select first tool
    M501 ; Store parameters
    8/15/2020, 8:57:43 AM Emergency stop, attemping to reconnect...
    8/15/2020, 8:57:42 AM Warning: Firmware halted
    8/15/2020, 8:57:38 AM Error: short-to-ground reported by driver(s) 0 1 2 4
    8/15/2020, 8:57:34 AM Error: short-to-ground reported by driver(s) 2 4
    8/15/2020, 8:57:29 AM Error: short-to-ground reported by driver(s) 2 4
    8/15/2020, 8:57:25 AM Error: short-to-ground reported by driver(s) 2 4
    8/15/2020, 8:57:20 AM Error: short-to-ground reported by driver(s) 2 4
    8/15/2020, 8:57:16 AM Error: short-to-ground reported by driver(s) 2 4
    8/15/2020, 8:57:11 AM Error: short-to-ground reported by driver(s) 2 4
    8/15/2020, 8:57:07 AM Error: short-to-ground reported by driver(s) 2 4
    8/15/2020, 8:57:02 AM Error: short-to-ground reported by driver(s) 2 4
    8/15/2020, 8:56:58 AM Error: short-to-ground reported by driver(s) 2 4
    8/15/2020, 8:56:53 AM Error: short-to-ground reported by driver(s) 2 4
    8/15/2020, 8:56:49 AM Error: short-to-ground reported by driver(s) 2 4
    8/15/2020, 8:56:44 AM Error: short-to-ground reported by driver(s) 2 4
    8/15/2020, 8:56:40 AM Error: short-to-ground reported by driver(s) 2 4
    8/15/2020, 8:56:36 AM Error: short-to-ground reported by driver(s) 2 4
    8/15/2020, 8:56:31 AM Error: short-to-ground reported by driver(s) 2 4
    8/15/2020, 8:56:17 AM Connected to 10.102.1.114
  • Moderator
    @maxspongebob sorry for the inconvenience, this is a known issue with a short run of boards. Please see this thread for info and what to do: https://forum.duet3d.com/topic/18011/duet-3-6hc-short-to-ground-issue?
    In short, contact Duet3D for a warranty replacement.
