Error: Failed to parse major T-code number (o)
  • Getting an error now whenever I upload a file to print. old prints previously loaded can run:
    Here is the firmware:
    FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-05-19b2
    Error:
    8/16/2020, 4:14:01 PM M32 "0:/gcodes/t.gcode"
    8/16/2020, 4:14:01 PM Upload of t.gcode successful after 0s
    config file:
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Aug 13 2020 09:44:43 GMT-0700 (Pacific Daylight Time)
    M550 P"Duet 3" ; set printer name
    M669 K1 ; select CoreXY mode
    M569 P0.1 S1 ; physical drive 0.1 goes forwards
    M569 P0.2 S0 ; physical drive 0.2 goes backwards
    M569 P0.3 S1 ; physical drive 0.3 goes forwards
    M569 P0.4 S1 ; physical drive 0.4 goes forwards
    M584 X0.0 Y0.1 Z0.2 E0.3:0.4 ; set drive mapping
    M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
    M92 X160.00 Y160.00 Z640.00 E822.67:822.67 ; set steps per mm
    M566 X600.00 Y600.00 Z300.00 E3600.00:3600.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X120000.00 Y120000.00 Z1200.00 E4800.00:4800.00 ; set maximum speeds (mm/min)
    M201 X800.00 Y800.00 Z30.00 E80.00:80.00 ; set accelerations (mm/s^2)
    M906 X1800 Y1800 Z3200 E1800:1800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S20 ; Set idle timeout
    M208 X450 Y280 Z320 S0 ; set axis maxima
    M574 X2 S1 P"io1.in" ; configure active-high endstop for high end on X via pin io1.in
    M574 Y1 S1 P"!^io2.in" ; configure active-high endstop for low end on Y via pin !^io2.in
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    M558 P5 C"^!io3.in" H2 F150 T1800 ; set Z probe type to switch and the dive height + speeds
    M558 H2 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
    G31 P1000 X0 Y0 Z0.722 ; set Z probe trigger value, offset and trigger height
    M557 X0:450 Y20:280 S20 ; define mesh grid
    M308 S0 P"temp0" Y"pt1000" R2200 ; configure sensor 0 as PT1000 on pin temp0
    M143 H0 S170 ; set temperature limit for heater 0 to 150C
    M308 S1 P"temp1" Y"pt1000" R2200 ; configure sensor 1 as PT1000 on pin temp1
    M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
    M143 H1 S450 ; max temp for extruder 450c
    M308 S2 P"temp2" Y"pt1000" R2200 ; configure sensor 2 as PT1000 on pin temp2
    M950 H2 C"out2" T2 ; create nozzle heater output on out2 and map it to sensor 2
    M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
    M308 S3 P"temp3" Y"pt1000" R2200 ; define bed temperature sensor
    M950 H3 C"out3" T3 ; create bed heater output on out3 and map it to sensor 3
    M141 H3 ; heater 3 is the chamber heater
    M563 P0 S"Mosquito Main 0" D0 H1 F0 ; define tool 0
    M563 P1 S"Mosquito Support 1" D1 H2 F0 ; define tool 1
    G10 P1 X16.150 Y2.15 Z0 ; set tool 1 axis offsets
    G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
    M501 ; enable config override
    M572 D0 S0.7 ; enable pressure advance
  • Moderator
    @gt40 said in Error: Failed to parse major T-code number (o):
    t.gcode"
    Is the file actually named t.gcode?
    What version of DWC are you using?
    Is this Duet 3 standalone or with SBC?
  • The file is really named t.gcode.
    It was just a test print file to see if the problem repeats. Every file try to print now fails to print with the same error.
    Here is the file
    t.gcode
    It is duet 3 with sbc: FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-05-19b2
    Thanks,
    Mark
  • Moderator
    But other files named differently work?
    Can you delete the t.gcode file?
  • Moderator
    Thanks for your report. I think @chrishamm might have to take a look at this one.
  • @Phaedrux
    I cannot run any new files regardless of the name. Only files previously printed. If I attempt to print it just gives the same error. I have tried this multiple times.
    Have you recently changed your slicer settings, in particular the start GCode?
  • You nailed it. I had a change in my starting script for simplify that fixed it once removed.
    Thanks for the help and mark this solved.
    Mark
  • Moderator
    What did you have in there that was throwing it for a loop?
