    What should be my first calibration steps on a new build?
    550
    • hbrownellundefined
      hbrownell
      I have a BLV Mod frame and I've built it up with genuine parts.
      I'm wanting to print for accuracy as I want to build hobby parts that need to fit together and work. SO, I'm putting it to you, what are my first calibration steps?
      What I've done thus far. My bed is level. Hurrah. I can print using mesh bed compensation.
      I printed a cube for line thickness testing. I am printing with a .4mm nozzle and with flow rate down to 50% I can get .4 line width. However, doing any other kind of complicated print falls apart with not nearly enough material being layed down.
      My e-steps are calibrated on my carriage and extruder as well. So when I move or extrude by X I get X as the number. (Or less than a millimeter)
      I'm sure there are already lots of threads on this, but I am having a hard time finding them. so thanks in advance!!
      GO!!
      • jens55undefined
        jens55
        Why would you try to extrude at a 50% flow rate ?
        Flow rate is adjusted to fine tune the extrusion rate that you adjusted earlier.
        Use 100% unless you have a good reason for any variation.
        You can not expect a reasonable print at 50% flow rate.
          hbrownell
          Just trying to follow youtube videos and trying to learn. That's why I'm posting here. You're right, the prints are garbage doing anything past a cube, but when I print at 100% I get .8 or greater thickness.. so again.. looking for actual steps or good practices 🙂
          jens55undefined 1 Reply Last reply Reply Quote 0
          • QuintBrandundefined
            QuintBrand
            You can get the same line thickness as the nozzle size, but it's typically better to add some 20-25% (you can choose but this is a good indication). It makes printing easier and can also be more esthetic.
            So I use 0,3mm on a 0.2mm nozzle and 0,5mm with 0,4mm nozzle. Put the 0,5mm in Cura as line width and the flow should then be around 90% (you trest for yourself) to achieve this width and that's then good. Don't go too quick when printing the "vase mode) cube (wall).
            Then you want to do the non linear extrusion speed test (m593 or something in that range from the top of my head) to get consistent extrusion amount with different extrusion speed. There are excel sheets here in the forum to help you with the math if you like.
            Should cover the line width. Other things to calibrate is retraction and bridging. There are nice tests you can print found on thingiverse.
            Holes are typically print too small, cura now had some horizontal expension parameter for getting holes print just right. Might be right for you but I typically use a drill if possible.
            Cheers
            PS: https://youtu.be/rp3r921DBGI
            • fcwiltundefined
              fcwilt
              Consider the idealized images below.
              The two circles on the left represent using line width that matches the nozzle size.
              The two ovals on the right represent using a line width that is greater than the nozzle size.
              As you can see you get much more contact between layers with a oval shape.
              More contact will normally yield a stronger print.
              • jens55undefined
                jens55 @fcwilt
                @fcwilt said in What should be my first calibration steps on a new build?:
                This is misleading as you play down layer height. If you have a 0.4 mm nozzle and a 0.2 mm layer height you will never get the round shape on the left of your picture.
                • jens55undefined
                  jens55 @hbrownell
                  @hbrownell said in What should be my first calibration steps on a new build?:
                  If you print at 100% flow and you get 0.8 mm wide layers but have specified 0.4 mm wide layers in your slicer than you have a mis-configuration someplace. You may have incorrectly set up extrusion steps or you may have a nozzle tat is too low to the build plate.
                  You said you calibrated the extrusion step value. Did you calibrate that by extruding through the nozzle at the right temperature? Did you mark the filament 100 mm in front of the extruder and then did you do an extrusion of 100 mm? Did the mark on the filament end up just in front of the extruder?
                  There are multiple ways to specify extrusion flow - for example there is a separate setting for flow for the first layer - did you verify that setting ?
                  Have you measured what the layer height is (after the build plate cooled down and after you removed your test layer off the bed)? Don't peel the layer with a hot build plate as it will distort the layer you are trying to measure.
                  • jens55undefined
                    jens55
                    Post your config.g just in case there is something odd there.
                    What slicer are you using ?
                    Did you configure your slicer for RRF (Rep Rap Firmware) ? If you have configured the slicer for the wrong firmware, all kinds of odd things start happening.
                    BTW, you shouldn't have seen a reasonable cube test print either.
                      hbrownell
                      My nozzle is a .4, so again learning I'm thinking I could have a .4 wall. Maybe that's unrealistic. I have a duet3d board and use the configurator to put it together. I'm using cura 4.4.1
                      I can post my config if that helps.
                      • fcwiltundefined
                        fcwilt @jens55
                        @jens55 said in What should be my first calibration steps on a new build?:
                        That's why I qualified it and did not specify a layer height of 0.2.
                        It was simply to point out the importance of good contact between layers, which under extrusion may prevent.
                        • jens55undefined
                          jens55
                          You can have a 0.4 mm wall although there is an argument to be made to set your wall line to 0.5 mm (I use 0.4mm line width if I use a 0.4 mm nozzle).
                          Yes, post your config.g
                          Have you measured the layer height of your first layer (the one you say is 0.8 mm wide?)
                            https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
                            You might get something out of this as a starter.
                            And then maybe this: https://forum.duet3d.com/post/130939
                              hbrownell
                              Height is .3
                              Config
                              ; generated by RepRapFirmware Configuration Tool v2 on Fri May 24 2019 20:44:40 GMT-0500 (Central Daylight Time)
                              M550 P"3DPrinter" ; Set machine name
                              M552 S1 ; Enable network
                              M586 P0 S1 ; Enable HTTP
                              M586 P1 S0 ; Disable FTP
                              M586 P2 S0 ; Disable Telnet
                              M569 P0 S0 ; Physical drive 0 goes Backwards
                              M569 P1 S0 ; Physical drive 1 goes Backwards
                              M569 P2 S1 ; Physical drive 2 goes forwards
                              M569 P3 S0 ; Physical drive 3 goes forwards
                              ;current settings
                              M584 X0 Y1 Z2:4 E3; two Z motors connected to driver outputs Z and E1
                              M671 X-81.5:291.5 Y110:110 S2 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
                              M92 X99.9 Y100.1 Z399.6183 E99. ; Set steps per mm
                              M566 X900.00 Y900.00 Z12.00 E110.00 ; Set maximum instantaneous speed changes (mm/min)
                              M203 X6000.00 Y6000.00 Z4000.00 E1200.00 ; Set maximum speeds (mm/min)
                              M201 X500.00 Y500.00 Z20.00 E250.00 ; Set accelerations (mm/s^2)
                              M906 X1100.00 Y1100.00 Z1100.00 E1100.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
                              M84 S30 ; Set idle timeout
                              ; Axis Limits old
                              ;M208 X20 Y0 Z0 S1 ; Set axis minima
                              ;M208 X230 Y210 Z200 S0 ; Set axis maxima
                              ;New Settings
                              M208 X-20:230 Y-20:230 ; X carriage moves from 0 to 210, Y bed goes from 0 to 210
                              M574 X1 Y1 S1 ; Set active high endstops
                              M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
                              ; new suggested settings
                              M558 P9 H5 F120 T6000 A5 T0.0 ; Set Z probe type to bltouch and the dive height + speeds (F100 T2000 original settings)
                              ;M558 P9 H10 F500 T4000 X0 Y0 Z1 ; Set Z probe type to bltouch and the dive height + speeds (F100 T2000 original settings)
                              G31 P25 X34.82 Y-8 Z-.033 ; Set Z probe trigger value, offset and trigger height
                              M557 X0:210 Y15:210 S52.5 ; Define mesh grid
                              M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                              M106 P0 S0 I0 F500 H T45 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on
                              M563 P0 D0 H1 ; Define tool 0
                              bed
                              ;Suggested settings from the Duete3D Dozuki.com
                              G28 ; home
                              ;M401 ; deploy Z probe (omit if using bltouch)
                              G30 P0 X35 Y105 Z-99999 ; probe near a leadscrew, half way along Y axis
                              G30 P1 X205 Y105 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
                              ;M402 ; retract probe (omit if using bltouch)
                              • jens55undefined
                                jens55
                                I can't see anything obviously wrong here that would account for your issues.
                                Are you saying that your first layer is 0.3mm high and 0.8 mm wide ?
                                What are your slicer settings for first line width and height ?
                                  hbrownell
                                  That's correct
                                  Layer H .2
                                  Initial Layer H .3
                                  Line Width .4
                                  Wall line .8
                                  Outer .8
                                  Inner .8
                                  Top / Bottom .4
                                  Infill .4
                                  Initiall layer line width 100%
                                  Wall line count 1
                                  Top bottom thickness .8
                                  Top layer 2
                                  Bottom layers 2
                                  Enable ironing checked
                                  Infill Desity 40
                                  Infil line distance 1mm
                                  Temp 205
                                  Plate 70
                                  Ratraction Distance 2
                                  Retraction speed 25mm/s
                                  Print speed 40
                                  Enable accelration control checked
                                  Enable jerk control checked
                                  • jens55undefined
                                    jens55
                                    I am out of ideas, sorry ....
                                    One thing though .... you say you measured line width at 0.8 mm ... was that measuring a SINGLE line or did you measure wall thickness (which is two lines and should be 0.8 mm)?
                                      hbrownell
                                      Single line
