Wifi not working
Wifi quite working shortly after I got the board it worked for a little while. I set up board properly with YAT. I configured it properly with the reprap configuration site. Set up its own IP and it just will not work. I do not have a screen to plug in so I was relying completely on wifi to run the machine
@bradh Please see this post for the kind of detail you need to supply when asking for help. https://forum.duet3d.com/post/53522
Otherwise my best guess is that it’s not reading the SD card.
My apologies it is duet 2, firmware is 2.05.1 and this is the configuration link https://configtool.reprapfirmware.org/Finish
duet 2 wifi
@bradh said in Wifi not working:
the result is only shown in your browswer, the url has a blank config for everyone else. upload or include the config.g you downloaded please.
tpre0.g tpost0.g tfree0.g stop.g sleep.g resume.g pause.g homez.g homey.g homex.g homeall.g config.json config.g bed.g
M552 P192.168.1.25 S1
Are you sure that IP address is free to assign statically? It's better practice to use DHCP and use the router to reserve an IP address for the device. No chance of address conflicts that way.
If you connect via USB terminal what do you get if you send M552 by itself?
thanks for your help but I sent board in now so they will be able to do diagnostics on it
I have had intermittent wifi issues since install. It would constantly disconnect. After reading a seggestion in forums I realized I had created a "faraday cage" between my duet board and modem. A cheap wall plug wifi booster, closer and without metal obstructions between modem and booster, fixed the problem.
