    Duetwifi 3.1.0 software reset, 3.1.0 little buggy?
    • seraserundefined
      seraser
      Hello.
      Log:
      === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.0 running on Duet WiFi 1.02 or later Board ID: 08DGM-917NK-F23T0-6JKF2-3S86S-KYB0D Used output buffers: 3 of 24 (17 max) === RTOS === Static ram: 28180 Dynamic ram: 92780 of which 60 recycled Exception stack ram used: 264 Never used ram: 9788 Tasks: NETWORK(ready,112) HEAT(blocked,1224) MAIN(running,1896) IDLE(ready,80) Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:42:34 ago, cause: software Last software reset at 2020-08-18 21:05, reason: Stack overflow, spinning module GCodes, available RAM 9408 bytes (slot 3) Software reset code 0x4103 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80e BFAR 0xe000ed38 SP 0x2001ffb4 Task NETW Stack: 20002860 20002894 00455625 00000000 00000000 200029b8 00000000 a0000000 00454c35 200028c4 200055f4 Error status: 0 MCU temperature: min 62.7, current 62.9, max 80.0 Supply voltage: min 13.0, current 13.1, max 13.2, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, SG min/max not available Driver 1: standstill, SG min/max not available Driver 2: standstill, SG min/max not available Driver 3: standstill, SG min/max not available Driver 4: standstill, SG min/max not available Date/time: 2020-08-18 21:47:34 Cache data hit count 4088977013 Slowest loop: 5.96ms; fastest: 0.14ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 1.5ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms Bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 126.23ms; fastest: 0.00ms Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
      HTTP sessions: 1 of 8 - WiFi - Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.23 WiFi MAC address 84:f3:eb:41:a6:9c WiFi Vcc 3.39, reset reason Unknown WiFi flash size 4194304, free heap 22456 WiFi IP address 192.168.0.25 WiFi signal strength -74dBm, reconnections 0, sleep mode modem Socket states: 4 0 0 0 0 0 0 018/8/2020
      Maybe Mcu at 80 temp is the problem?
      Printing abs in enclosure
        jay_s_uk @seraser
        @seraser update to 3.1.1 as there were issues with 3.1.0
        seraserundefined 1 Reply Last reply Reply Quote 0
        • seraserundefined
          seraser @jay_s_uk
          @jay_s_uk said in Duetwifi 3.1.0 software reset, 3.1.0 little buggy?:
          Thank you very much, will do.
            The stack overflow in that M122 report is the issue that 3.1.1 was released to fix.
