Z axis wont home
Tim, thanks for that. Brian, you had better talk to aus3d if you are using their sensor. It's my sensor (also so!d by Duet3D and Filastruder) that should flash 4 times at startup when connected to a Duet.
I think i have found the error, as i've mount the duet upside down, and with small print its hard to see clearly. I'll check until i'm convinced i see it right.
I changed the ground on the sensor to the next position on the duet .
It still only flashes twice on start up, but when bed approches the sensor a red led lights up until bed is moved away.
Now the home z only moves the bed down a bit, but the home all works!!!
Finally got the z probe offset to work, it resisted a lot, but is good now.
Just want to thank dc42, elmoret, and CaLviNx for getting me thru this.
Just love a happy ending.
