    Limit Switch Trouble
    234
    • amostol
      amostol last edited by
      Hi I'm having trouble with my limit switches. I'm using the makerbot switch's, I made sure the wires are connected correctly and I'm using RepRapFirmware 3.
      The problem is that when I run the home command, it does nothing unless I close the limit switch, then it will home until I release the switch, they are working backwards. When I close the switch, the light comes on just like it should. I have tried it with it set to both active high and active low, I even went into the config file to confirm whether or not a ! was in front of the pin name, ! for active low and nothing for active high.
      What is going on? I have used the Duet 2 wifi before (which is what I'm using) and never had this problem before even with the very same limit switches. It started doing it with my original board, at first I though maybe I had the wires wired up wrong and maybe that damaged the board, so I bought a new board but it does the same thing.
      peter247 1 Reply Last reply Reply Quote 0
        Please post your config file.
        Confirm that you have firmware 3.1.1 installed by sending M115.
        • peter247
          peter247 @amostol last edited by
          @amostol said in Limit Switch Trouble:
          makerbot switch's
          M574 X2 S1 P"!xstop"
          M574 Y2 S1 P"!ystop"
          That is my set up.
          Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
          • amostol
            Here is my config file
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Aug 19 2020 16:46:44 GMT-0700 (Pacific Daylight Time)
            M550 P"My Printer" ; set printer name
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P8 S1 ; physical drive 8 goes forwards
            M584 X8 Y1 Z2 E3 ; set drive mapping
            M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
            M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
            M906 X800 Y800 Z1800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X485 Y485 Z485 S0 ; set axis maxima
            M574 X2 S1 P"!xstop" ; configure active-high endstop for high end on X via pin xstop
            M574 Y2 S1 P"!ystop" ; configure active-high endstop for high end on Y via pin ystop
            M574 Z2 S1 P"!zstop" ; configure active-high endstop for high end on Z via pin !zstop
            M558 P1 C"zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
            G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
            M557 X15:215 Y15:195 S20 ; define mesh grid
            peter247 droftarts 2 Replies Last reply Reply Quote 0
            • peter247
              peter247 @amostol last edited by peter247
              @amostol can you post the first few lines of m122 ?
              You may be on version 3 config , but are you on version 3 firmware ?
              m122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
              Board ID: 08DGM-95BLL-N6PSS-6JTD6-3SJ6K-K0UZJ
              Used output buffers: 3 of 24 (21 max)
              • droftarts
                droftarts administrators @amostol last edited by
                @amostol Can you show a picture of the wiring, on the endstop switch and on the Duet? If you send M119, what does the endstops report when not pressed? While our guide here https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Makerbot_Mechanical_Endstop_v1_Num_2 says to invert these endstops with '!', it may be that you have a version that does not need inversion.
                As others have already said, please post your firmware version.
                • amostol
                  It says
                  "RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
                  Board ID: 08DJM-9178L-L2MS8-6J1FL-3SN6N-KVFYR
                  Used output buffers: 3 of 24 (10 max)"
                  I just updated it to 3, I do not understand why it is saying version 2, I guess I'll have to try updating again.
                  I have tried it without the ! and it makes no difference. Thanks for the help.
                    That explains it. Your config is for RRF3 but your firmware is still RRF2.
                    You'll need to update to 3.0 and then 3.1.1. Perhaps you tried to go straight to 3.1.1?
                    Easiest way is to upload the entire 3.0 zip file as is (don't extract it yourself) to the /sys folder via DWC. It should be detected and automatically update everything needed.
                    Then do the same thing with the 3.1.1 zip file.
                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
                    https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/Duet2and3Firmware-3.1.1.zip
                    • peter247
                      @amostol
                      Looks like I was spot on that you have config.g / firmware mismatch.
                      Upgrade to version 3 or use the version 2 configurator
                      • amostol
                        I updated it and now it works, I most have done something wrong the first time I tried to update it.
                        Thanks for your help, I really appreciate it.
