    Duet 3 chamber heater setup issue
    • gt40undefined
      gt40
      I am trying to get my chamber heater working on my Duet 3. I am using an SSR and if I provide the SSR with voltage it triggers and the heater works. When I try to activate it with DWC, it just faults because there is no change in temp and I get the rising too slowly error.
      Here is the relevant section of my config file on the chamber heater:
      M308 S3 P"temp3" Y"pt1000" R2200 ; configure sensor 3 as PT1000 on pin temp3
      M950 H3 C"out3" T3 ; create bed heater output on out0 and map it to sensor 3
      M141 H3 ; Define heater h3 as chamber heater
      M301 H3 P-1 ; Disable PID settings to use bang-bang
      M143 H3 S150 ; set temperature limit for heater 3 to 150C
      I am using Duet Web Control 3.1.1. Note the temp is correct and reflects change if you manually cycle the ssr.
      Any suggestions would be appreciated.
      Thanks,
      Mark
        Have you tried to PID tune the heater yet? If you can get it to tune it will have a model of its performance and won't error anymore.
        Chambers are tricky though because they heat so slowly, it's difficult to know if it's actually heating or if there is a fault.
        Where is your thermistor located? The closer the sensor is to the heater the tighter the control loop.
        If it can't auto tune, you can derive your own PID values.
        Have you seen these?
        https://duet3d.dozuki.com/Wiki/Connecting_and_configuring_a_chamber_heater
        https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
        • gt40undefined
          gt40
          I tried to tune as you suggested:
          The SSR has an LED that lights when it is activated and it didn't turn on during tuning. It will activate if I supply voltage to the terminals so I verified it works.
            Post your full config please.
            Also what wires go where on your duet 3? Post a photo?
              Try using M307 to increase the dead time parameter to 60 seconds before tuning.
              • gt40undefined
                gt40
                I switched from out3 to out7 and mapped it per config file below and it works. I am not sure why but at least the chamber heater works now and I was able to tune it.
                ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Aug 13 2020 09:44:43 GMT-0700 (Pacific Daylight Time)
                M550 P"Duet 3" ; set printer name
                M669 K1 ; select CoreXY mode
                M569 P0.1 S1 ; physical drive 0.1 goes forwards
                M569 P0.2 S0 ; physical drive 0.2 goes backwards
                M569 P0.3 S1 ; physical drive 0.3 goes forwards
                M569 P0.4 S1 ; physical drive 0.4 goes forwards
                M584 X0.0 Y0.1 Z0.2 E0.3:0.4 ; set drive mapping
                M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
                M92 X160.00 Y160.00 Z640.00 E822.67:822.67 ; set steps per mm
                M566 X600.00 Y600.00 Z300.00 E3600.00:3600.00 ; set maximum instantaneous speed changes (mm/min)
                M203 X120000.00 Y120000.00 Z1200.00 E4800.00:4800.00 ; set maximum speeds (mm/min)
                M201 X800.00 Y800.00 Z30.00 E80.00:80.00 ; set accelerations (mm/s^2)
                M906 X1800 Y1800 Z3200 E1800:1800 I30 ; set motor currents (mA) and motor idle factor in per cent
                M84 S20 ; Set idle timeout
                M208 X450 Y280 Z320 S0 ; set axis maxima
                M574 X2 S1 P"io1.in" ; configure active-high endstop for high end on X via pin io1.in
                M574 Y1 S1 P"!^io2.in" ; configure active-high endstop for low end on Y via pin !^io2.in
                M574 Z1 S2 ; configure Z-probe endstop for low end on Z
                M558 P5 C"^!io3.in" H2 F150 T1800 ; set Z probe type to switch and the dive height + speeds
                M558 H2 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                G31 P1000 X0 Y0 Z0.722 ; set Z probe trigger value, offset and trigger height
                M557 X0:450 Y20:280 S20 ; define mesh grid
                M308 S0 P"temp0" Y"pt1000" R2200 ; configure sensor 0 as PT1000 on pin temp0
                M143 H0 S170 ; set temperature limit for heater 0 to 170C
                M308 S1 P"temp1" Y"pt1000" R2200 ; configure sensor 1 as PT1000 on pin temp1
                M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
                M143 H1 S450 ; set temperature limit for heater 1 to 450C
                M308 S2 P"temp2" Y"pt1000" R2200 ; configure sensor 1 as PT1000 on pin temp1
                M950 H2 C"out2" T2 ; create nozzle heater output on out1 and map it to sensor 1
                M143 H2 S450 ; set temperature limit for heater 2 to 450C
                M950 H3 C"out7" T3 ; create bed heater output on out7 and map it to sensor 3
                M141 H3 ; Define heater h7 as chamber heater
                M563 P0 S"Mosquito Main 0" D0 H1 F0 ; define tool 0
                M563 P1 S"Mosquito Support 1" D1 H2 F0 ; define tool 1
                G10 P1 X16.150 Y2.15 Z0 ; set tool 1 axis offsets
                G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
                M501 ; enable config override
                M572 D0 S0.7 ; enable pressure advance
