Blown fuse on 1.01 Duet Wifi
  • A bit of a long story, but I was testing a new heater core on the printer and something sorted out the VSSA temp sensors which now read at 2000c.
    I have gone through quite a bit of testing to determine it is the fuse. After visiting the replacement part website https://duet3d.dozuki.com/Wiki/Connector_and_spare_part_numbers
    I can solder things but not well and I don't have a hot air setup to remove tiny parts. I think the 2nd option of adding a bladed fuse could be doable?
    Has anyone tried this and could provide me with a few pictures on where to best put a fuse? anyone have a good part number? I am so/so on the soldering iron....
    Thanks for any help you can provide!
    Jim
  • isn't the pictures on the wiki page clear enough, or did you mean pictures of where to put a blade fuse?
    are you using all your thermistor inputs?
