SOLVED M584 won't swap X/Y motor axes
  • Duet 3 6HC board
    M115
    FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.01-RC9 ELECTRONICS: Duet 3 MB6HC v1.01 or later FIRMWARE_DATE: 2020-04-21b1
    My X and Y axes are swapped. I don't want to change the wiring. It seems like this should be very doable in firmware.
    The M584 command sets motors to axes, but swapping the motor on X and Y doesn't change the result.
    The result for me is that if I want to move 10mm in the X axis, it moves in the Y axis instead.
    What am I doing wrong?
    It seems like the configuration is taking place. The gantry moved in the Y direction on both of these G0 commands.
    Config below:
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Jul 29 2020 21:58:06 GMT-0400 (Eastern Daylight Time)
    G90                                          ; send absolute coordinates...
    M83                                          ; ...but relative extruder moves
    M550 P"TankXY"                               ; set printer name
    M669 K1                                      ; select CoreXY mode
    M552 P0.0.0.0 S1                             ; enable network and acquire dynamic address via DHCP
    M586 P0 S1                                   ; enable HTTP
    M586 P1 S0                                   ; disable FTP
    M586 P2 S0                                   ; disable Telnet
    M569 P0.0 S1                                 ; physical drive 0.0 goes forwards
    M569 P0.1 S1                                 ; physical drive 0.1 goes forwards
    M569 P0.2 S0                                 ; physical drive 0.2 goes backwards
    M569 P0.3 S0                                 ; physical drive 0.3 goes backwards
    M569 P0.4 S0                                 ; physical drive 0.4 goes backwards
    M569 P0.5 S1                                 ; physical drive 0.5 goes forwards
    M584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5             ; set drive mapping
    ;M584 X0.1 Y0.0 Z0.2:0.3:0.4 E0.5             ; set drive mapping
    M350 E16 Z16 I1                              ; configure microstepping without interpolation
    M350 X16 Y16 I1                              ; configure microstepping with interpolation
    M92 X80.00 Y80.00 Z1600.00 E420.00           ; set steps per mm
    M350 X256 Y256 Z256 I0
    M566 X900.00 Y900.00 Z12.00 E120.00          ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00      ; set maximum speeds (mm/min)
    M201 X500.00 Y500.00 Z20.00 E250.00          ; set accelerations (mm/s^2)
    M906 X1000 Y1000 Z1000 E1000 I30             ; set motor currents (mA) and motor idle factor in per cent
    M84 S15                                      ; Set idle timeout
    M208 X-115 Y-115 Z0 S1                       ; set axis minima
    M208 X115 Y115 Z200 S0                       ; set axis maxima
    ;M574 X1 S3                                   ; configure sensorless endstop for low end on X
    ;M574 Y1 S3                                   ; configure sensorless endstop for low end on Y
    ;M558 P0 H5 F120 T6000                        ; disable Z probe but set dive height, probe speed and travel speed
    ;M557 X-75:75 Y-75:75 S50                     ; define mesh grid
    ;M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
    ;M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
    ;M307 H0 B0 S1.00                             ; disable bang-bang mode for the bed heater and set PWM limit
    ;M140 H0                                      ; map heated bed to heater 0
    ;M143 H0 S120                                 ; set temperature limit for heater 0 to 120C
    ;M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
    ;M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1
    ;M307 H1 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
    ;M950 F0 C"out3" Q500                         ; create fan 0 on pin out3 and set its frequency
    ;M106 P0 S0 H-1                               ; set fan 0 value. Thermostatic control is turned off
    ;M950 F1 C"out4" Q500                         ; create fan 1 on pin out4 and set its frequency
    ;M106 P1 S1 H1 T45                            ; set fan 1 value. Thermostatic control is turned on
    ; set case fans to be controlled off of MCU temperature
    M950 F2 C"!out6" Q2000
    M308 S2 Y"mcu-temp" A"MCU"
    M106 P2 T50:80 H2 S1.0
    ;M563 P0 S"Extruder" D0 H1 F0                 ; define tool 0
    ;G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
    ;G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
    ;M501                                         ; load saved parameters from non-volatile memory
    ;T0                                           ; select first tool
  • Oh, I think I get it. I need to reverse direction of one motor.
    Yeah that solved it. The CoreXY kinematics were complicating the understanding of what was going on.
  • Moderator
    @TDK said in M584 won't swap X/Y motor axes:
    3.01-RC9
    Update your firmware to 3.1.1 too to avoid getting bitten by bugs.
