    I want to control respectively 4 motors already mapped to Z-axis
    • psyblue
      psyblue last edited by psyblue
      Four motors are used on the z-axis. The bed is 1000mm by 500mm, 10mm thick aluminum, very rigid.
      I'm struggling to automate bed leveling.
      The procedure I want to try is :
      1. Mapping 2 out of 4 motors as if they were one
      2. Automatic 3 point bed leveling
      3. Manually adjust gap where the bed is floating.
      To do this, we need a method of bundling two motors and treating them as one motor.
      • PCR
        PCR last edited by
        you can easily map them.
        for example
        M569 P0 S0                                     ; physical drive 0 goes backwards
        M569 P1 S0                                     ; physical drive 1 goes backwards
        M569 P2 S1                                     ; physical drive 2 goes forwards
        M569 P3 S1                                     ; physical drive 3 goes backwards
        M569 P4 S1                                     ; physical drive 4 goes backwards
        M569 P5 S1                                     ; physical drive 5 goes backwards
        M569 P6 S1                                     ; physical drive 6 goes backwards
        M584 X0 Y1 Z2:3:4:5 E6                               ; set drive mapping
        In the M906 you need only one Z parameter
        M906 X800 Y800 Z800 E1000 I50                  ; set motor currents (mA) and motor idle factor in per cent
        After that you can use this wiki entry
        https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
        psyblue 1 Reply Last reply Reply Quote 1
        • psyblue
          psyblue @PCR last edited by
          @PCR
          Thank you for your reply.
          I'm already doing it the same way you do, and I already know the wiki.
          My question is some sloppy, so I want to change the question,
          what if I want to control respectively the four motors already mapped to Z-axis?
          3 Z-axis bed leveling is so simple, but leveling 4 Z-axis has many limitations with rigid not flat bed.
          Veti 1 Reply Last reply Reply Quote 0
          • Veti
            Veti @psyblue last edited by
            @psyblue
            you could try assigning each of the z mother additional axis. to U, V, W, A and setting the P value so they are visible
            then you can manually control them as well.
            big but, it might be better if you convert one axis to just a support axis as 4 point bed levelling is problematic. see https://drmrehorst.blogspot.com/2017/07/3-point-print-bed-leveling-vs-4-point.html
