    Duet 2 PT100 Daughter Board K THERMALCOUPLE reading 2000c
    thermocouple duet 2 wifi pt100 2000c
    • freecharetteundefined
      freecharette
      I placed a 120 ohm resistor at pin 2 and 3 and get a reading of 49c the left or the right channel
      If i put in the K THERMALCOUPLE on pin 2 & 3 center pins i just get 2000c on the dashboard.
      At this point I have nothing connected to the Duet 2 wifi board just he PT100.
      just wonted to see if the board was working before i tear out the Ender 3 pro mainboard
      the daughter board is a 2 channel 4 pin Max 31865
      here is my config.g
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor
      M143 H0 S150 ; set temperature limit for heater 0 to 200C
      M308 S1 P"spi.cs2" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1 cs2 chan 2
      RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.01
      I just can't seem to get this to work
      If someone can direct to some possibilities.
      Thanks
        So you have a PT100 board, but you're trying to connect a thermocouple? I'm confused by your post.
        freecharetteundefined 1 Reply Last reply Reply Quote 0
          freecharette @Phaedrux
          @Phaedrux
          Yes have I made a mistake I thought that the two were needed for the K thermalcouple & the pt100 daughterboard to work on the duet 2
          Maybe I have some terms mixed up.
          • A Former User?
            A Former User
            if you have a k-type thermocouple, you need the thermocouple daugtherboard and not the pt100 daughterboard.
              https://duet3d.dozuki.com/Wiki/PT100_temperature_sensor_daughter_board
              https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors
              https://duet3d.dozuki.com/Wiki/Thermocouple_daughter_board
              https://duet3d.dozuki.com/Wiki/Connecting_thermocouples
                @Phaedrux
                Thank you
