    resume a print after a power failure or planned power down
    • sankafolaundefined
      sankafola
      Hello all, my setup is Duet 3 with SBC raspberry PI 3 , how to setup the resume ? i tried many times but not working ,
      and how to setup the smart effector in the configurator can we select it ?
      thanks
        Have you seen this?
        https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure
        Or this?
        https://duet3d.dozuki.com/Wiki/Smart_effector_and_carriage_adapters_for_delta_printer
          sankafola
          that is my resume.g file i have reprap firmware 3
          G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
          G1 R1 X0 Y0 ; go back to the last print move
          M83 ; relative extruder moves
          G1 E10 F3600 ; extrude 10mm of filament
          do i need to put anything in the config.g ?
            Phaedrux Moderator @Phaedrux
            @Phaedrux said in resume a print after a power failure or planned power down:
            Have you seen this?
