Can not home z and y
Hi I use micro switch as endstops, and i can home x when i do a "home all" but z and y is not home - I do not get any errors, and if I check to endstops only X is yes, z and y is no.
I got a duet 3 ver 1.0
Config :
; generated by RepRapFirmware Configuration Tool v3.1.3 on Sun Jul 05 2020 09:32:29 GMT+0200 (Centraleuropæisk sommertid); General preferences
M550 P"My Printer" ; set printer name; Network
M552 P192.168.1.123 S1 ; enable network and set IP address
M553 P255.255.255.0 ; set netmask
M554 P192.168.1.254 ; set gateway
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0.0 S1 ; physical drive 0.0 X goes forwards
M569 P0.1 S0 ; physical drive 0.1 X goes backwards 24-08-2020 2209
M569 P0.2 S1 ; physical drive 0.2 Y goes forwards
M569 P0.3 S0 ; physical drive 0.3 Z goes backwards 18-08-2020 2224
M569 P0.5 S1 ; physical drive 0.5 goes forwards
M584 X0.0:0.1 Y0.2 Z0.3 E0.5 ; set drive mapping 24-08-2020 2202
M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm 24-08-2020 2233
M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z1000.00 E1200.00 ; set maximum speeds (mm/min) 24-08-2020 2242
M906 X2100 Y1900 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent 28-08-2020 1753
M208 X1000 Y500 Z500 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!io0.in" ; configure active-low endstop for low end on X via pin io0.in 25-08-2020 0907
M574 Y1 S1 P"!io2.in" ; configure active-low endstop for low end on Y via pin io1.in 28-08-2020 1905
M574 Z1 S1 P"!io3.in" ; configure active-low endstop for low end on Z via pin io2.in 28-08-2020 1905; Z-Probe
;M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed 26-08-2020 0755
;M557 X15:215 Y15:195 S20 ; define mesh grid 26-08-2020 0755; Heaters
M308 S0 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp1
M950 H0 C"out1" T0 ; create nozzle heater output on out1 and map it to sensor 0
M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M308 S1 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp0
M950 H1 C"out0" T1 ; create nozzle heater output on out0 and map it to sensor 1
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"out3" Q500 ; create fan 0 on pin out3 and set its frequency
M950 F1 C"out4" Q500 ; create fan 1 on pin out4 and set its frequency
M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M122 :
M122
RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (standalone mode)
Board ID: 08DJM-956L2-G43S4-6J9FG-3S86T-KB5LD
Used output buffers: 1 of 40 (11 max)
Static ram: 154604
Dynamic ram: 162284 of which 44 recycled
Exception stack ram used: 512
Never used ram: 75772
Tasks: NETWORK(ready,324) ETHERNET(blocked,436) HEAT(blocked,1200) CanReceiv(suspended,3820) CanSender(suspended,1420) CanClock(blocked,1424) TMC(blocked,68) MAIN(running,4472) IDLE(ready,76)
Owned mutexes:
Last reset 00:15:05 ago, cause: software
Last software reset at 2020-08-28 19:06, reason: User, spinning module GCodes, available RAM 76060 bytes (slot 0)
Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
Error status: 0
MCU temperature: min 25.0, current 30.0, max 30.3
Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
Driver 0: standstill, reads 57941, writes 31 timeouts 0, SG min/max 0/534
Driver 1: standstill, reads 57942, writes 31 timeouts 0, SG min/max 0/502
Driver 2: standstill, reads 57943, writes 31 timeouts 0, SG min/max 0/286
Driver 3: standstill, reads 57936, writes 39 timeouts 0, SG min/max 0/430
Driver 4: standstill, reads 57964, writes 11 timeouts 0, SG min/max 0/0
Driver 5: standstill, reads 57962, writes 14 timeouts 0, SG min/max 0/0
Date/time: 2020-08-28 19:21:12
Slowest loop: 35.94ms; fastest: 0.14ms
=== Storage ===
Free file entries: 10
SD card 0 detected, interface speed: 25.0MBytes/sec
SD card longest read time 3.2ms, write time 1.8ms, max retries 0
Hiccups: 0(0), FreeDm: 375, MinFreeDm: 373, MaxWait: 68061ms
=== MainDDARing ===
Scheduled moves: 68, completed moves: 68, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
=== AuxDDARing ===
Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
Bed heaters = -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
SBC is idle in state(s) 0
Daemon is idle in state(s) 0
Aux2 is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 54.54ms; fastest: 0.03ms
Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
HTTP sessions: 1 of 8- Ethernet -
State: active
Error counts: 0 0 0 0 0
Socket states: 5 2 2 2 2 0 0 0
=== CAN ===
Messages sent 3645, longest wait 0ms for type 0
=== Linux interface ===
State: 0, failed transfers: 0
Last transfer: 905968ms ago
RX/TX seq numbers: 0/1
SPI underruns 0, overruns 0
Number of disconnects: 0
Buffer RX/TX: 0/0-0
Can anybody help me ?
- Ethernet -
@Finnls please post the homeall.g, this file is used for homing. And please tell which printer you have (model or type of kinematic Cartesian, CoreXY etc.).
Hi My printer is a Cartesian, and here is my homeall.g
; homeall.g
; called to home all axes
G91 ; relative positioning
G1 H2 Z5 F1000 ; lift Z relative to current position
G1 H1 X-1005 Y-505 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F1000 ; go back a few mm
G1 H1 X-1005 Y-505 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z-505 F360 ; move Z down stopping at the endstop
G90 ; absolute positioning
G92 Z0 ; set Z position to axis minimum (you may want to adjust this); Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G1 Z5 F100 ; lift Z relative to current position
;G90 ; absolute positioning
@Finnls this looks ok.
If you trigger the endstops manually (with the finger), does it show triggered correctly, for the right axes?
Yes the do.
G1 H1 X-1005 Y-505 F1800 - do not move y
G1 H2 X5 Y5 F1000 - do move yI have run homeall.g ono by one in console
@Finnls said in Can not home z and y:
what do you mean by "do not move y", it only moves X? With cartesian, both axes should move until both endstops are hit. Like described in https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareCartesianPrinter#Section_The_homeall_g_file
But you can test split command of course:
G1 H1 X-1005 F1800
G1 H1 Y-505 F1800The M574 S1 with ! means normally open switches, is this correct?
When I send G1 H1 Y-505 F1800 - Y moves between 1 to 6-7 mm and stops.
But Y is 0.0 in status.
My endstops are micro sw 2wire, one to gnd, and one to in
@Finnls looks like the Y endstop is activated immediately, maybe it's of type NC (normally closed) and you need to remove the ! in the M574 for Y.
Or a disturbing signal closed the switch immediately, please try moving the endstop wires with a little distance to other wires. (That's the reason why NC is recommended).
Or the printer vibrations trigger the endstop.
The Y 0.0 is a hint that the y endstop was triggered, because G1 H1 mode stops at the endstop and sets Y to the M208 limit, which is 0 in your case.
Not vibrations, but disturbing signal, I think you are on to something - maybe i need a resistor between in and 5v
@JoergS5 said in Can not home z and y:
Sorry I did not seen that - i can make it to NC. I will do that - Thanks
you would not need it, Duet 3's io.in have already pullup resistors:
https://duet3d.dozuki.com/Wiki/Connecting_endstop_switches#Section_Duet_3_endstop_inputsBut I expect using NC will solve the issue.
Thank you JoergS5 it is solved
@Finnls I'm pleased, thank you for confirmation!
