    RailCore II corexy
    My Duet controlled machine
    27
    118
    41.0k
    • Killerm1undefined
      Killerm1
      @kraegar Hi,
      Thanks for all the hard work on the railcore. I have just ordered the parts to build this 🙂
      was wondering if it is possible to get the model for the halo 300zl so i can get it milled locally? is way to expensive to get it sent to australia.
      • kraegarundefined
        kraegar
        The halo files will be released once they've been tested on a 300zl, and confirmed to work. Then I'll clean up a lot of cruft from the design, and publish it. Probably within a week or so of testing, depending on my work schedule.
        Co-Creator of the RailcoreII CoreXY printer
        https://www.thingiverse.com/thing:2407174
        Killerm1undefined jannisjundefined niksteelundefined 3 Replies Last reply Reply Quote 2
        • Wyvernundefined
          Wyvern
          Sweet, Linear rails on the Z axis, exactly what I was thinking about, lets see those feeble lead screws try to wobble that bed ha!
          kraegarundefined 1 Reply Last reply Reply Quote 0
          • kraegarundefined
            kraegar @Wyvern
            @wyvern Especially if you put the aluminum yokes on.
            • Killerm1undefined
              Killerm1 @kraegar
              @kraegar great! Thanks again
              • PlasticMetalundefined
                PlasticMetal
                What's up with the RailCore forum and wiki? The security certificates expired over 2 weeks ago on the forum, and 10 days ago on the wiki. Prior to that, the forum had been getting bombed by Russian spam, and it didn't seem any admins were paying attention.
                I'm trying my best to not get sucked into the cesspool that is Facebook, but it seems that's the only place still alive.
                • kraegarundefined
                  kraegar
                  Sorry, yeah. Our domain admin has been awol a bit now. We're migrating content from the wiki over to github ( https://railcore.github.io/ ). Not sure what we'll do with the forum long term yet, it was pretty under utilized.
                  In the meantime, #RailCore on IRC, or our discord channel at https://discord.gg/6kPKDRZ are good ways to communicate.
                    PlasticMetal
                    Thanks for the update and alternatives. Not a fan of Discord, either, but it's better than FB.
                    Are you still using SuperLube brand oil with PTFE for your linear rail carriages?
                    • kraegarundefined
                      kraegar
                      My personal go to is the superlube 21030 grease currently.
                        PlasticMetal
                        Sorry to be grumpy on the Discord comment - I realize it takes a lot of personal time to organize and maintain all these sites. My main concern with Discord, and one of the concerns with FB, is that information gets lost. Discord in particular is just a rolling chat. Forums allow much better organization of issues, and the invaluable search function.
                        • kraegarundefined
                          kraegar
                          I agree, but the forum just never gained any traction. The number of posts there was dwarfed by the use of both Facebook and now discord.
                          We still plan to get it back running once our admin resurfaces.
                            PlasticMetal
                            Cool. Hope to meet you at MRRF!
                            • kraegarundefined
                              kraegar
                              I'll definitely be there!
                              • jannisjundefined
                                jannisj @kraegar
                                @kraegar said in RailCore II corexy:
                                Any news about this?
                                Would be interesting to cnc this on a shopbot I got access to 🙂
                                -j
                                • niksteelundefined
                                  niksteel @kraegar
                                  @kraegar I saw the halo on 713maker -- would you recommend it for a new Railcore ZLT build? Is it possible to mount a lid over top?
                                  rbjam83undefined 1 Reply Last reply Reply Quote 0
                                  • rbjam83undefined
                                    rbjam83 @niksteel
                                    @niksteel I'm building a Railcore myself and while I don't intent to use the halo, I believe it can be enclosed. Check this link out: https://www.thingiverse.com/thing:3569321
                                    niksteelundefined 1 Reply Last reply Reply Quote 0
                                    • niksteelundefined
                                      niksteel @rbjam83
                                      @rbjam83 Thanks! looks like there's some variation in terms of where the belts fit, but the overall approach makes sense. It looks like you could use angle irons for most of it and then print some corner pieces to wrap around the motors and pulleys. Thanks and good luck with your project!
                                      • mikaelundefined
                                        mikael
                                        Could you use styrene-acrylonitrile (SAN) instead of HDPE for the side panels?
                                        HDPE: https://plastics.ulprospector.com/generics/27/c/t/polyethylene-pe-properties-processing/sp/5
                                        SAN:
                                        https://plastics.ulprospector.com/generics/47/c/t/styrene-acrylonitrile-san-properties-processing]
                                        SAN has a high Flexural Strength, and 1200X800X4 mm sheet is ~35€ and is transparent.
                                        What are the important mechanical parameters of the plastic panels of the railCore?
