    connecting neopixel or rgb led to duet2 with expansion board
    • tracarundefined
      tracar
      there seems to not be alot on this topic.
      i have neopixel strips and have regular rgb strips.
      is there an easy way to controll thru the duet wifi,
      anyone have a functioning led setup ?
        For one way, see https://www.thingiverse.com/thing:3382718 and in particular this image from it alt text
        Caution! Be very careful not to feed 5V from an Arduino to the Duet.
        tracarundefined 1 Reply Last reply Reply Quote 0
        • tracarundefined
          tracar @dc42
          nice find!
          i have this
          https://m.aliexpress.com/item/4000118902487.html?trace=wwwdetail2mobilesitedetail&spm=a2g0s.12269583.0.0.305a4310FPZwDw
          if i can only find a way to give it signal via the mic terminals, i mean rip it apart and feed it a signal to the pre or post microphone circuit.
          can duet have an output that could be used as this?
          my idea is to( convert a PWM output to an analog voltage level, producing a true DAC. All that is needed is a simple low-pass filter made from a resistor and a ceramic capacitor. The simple RC low-pass filter shown converts the PWM signal to a voltage proportional to the duty cycle.) from here:
          link text
          but to make the duet output diffrtnt signals and asign an output pin.
          it should work, I hope ,hahaha
