    [Solved] Haydn arms interrupt part cooling fans
    Third-party add-ons
    • toskiumundefined
      toskium
      Hello everybody,
      I am facing a bit of a problem with my smart effector and the attached part cooling fans.
      I have two 24V radial blowers connected to the part cooling connector, they work flawlessly when the smart effector is not connected to the Haydn arms but as soon as I connect both arms on the part cooling fan side that fan stops spinning. The second one stops as soon the other two arms are snapped on.
      This is the fan I am using: https://de.aliexpress.com/item/32798634077.html
      The smart effector is a genuine unit.
      Do you have a 24V radial blower recommendation that doesn't fail when the Haydn arms are near? 🙂
      Thanks!
      Markus
      • T3P3Tonyundefined
        T3P3Tony administrators @toskium
        @toskium does that happen if you try reversing one or the other of each pair of arms?
        www.duet3d.com
        toskiumundefined 1 Reply Last reply Reply Quote 0
        • toskiumundefined
          toskium @T3P3Tony
          @T3P3Tony oh, I didn't try that. Let me check 🙂
          • toskiumundefined
            toskium
            Thank you very much, you are my hero!
              dc42 administrators @toskium
              The grip is probably stronger that way too. It's mentioned in the Smart Effector assembly instructions that you should alternate N and S poles around the effector.
              • toskiumundefined
                toskium @dc42
                @dc42 you are right, that slipped my mind, my first delta printer and there is so much to learn. Thanks again!
