    Creating thermostatic fan without heater
    • davidvh86
      davidvh86 last edited by davidvh86
      Just trying to setup a thermostatic fan for my duet board cooling using a thermistor on e0temp . Whats tripping me up is would i need to create a new heater or can i just assign a sensor number? im using a thermocouple in place of my old e0 thermistor.
      sample of what im trying put in my config
      Heaters;
      M308 S3 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 3 as thermistor for board temp
      ;fans
      M106 P1 S1 H# T50 ; set fan 1 value. Thermostatic control is turned on
      Hes a copy of my config, fan2 thermostic control is currently off but the plan is to get it to turn on when e0 temp is above 50c
      M143 H0 S115 ; set temperature limit for heater 0 to 115C
      M308 S1 P"spi.cs1" Y"rtd-max31865" ; configure sensor 1 as thermocouple via CS pin spi.cs1
      M308 S2 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin e1temp
      M950 H2 C"e1heat" T2 ; create chamber heater output on e1heat and map it to sensor 2
      M307 H2 B1 S1.00 ; enable bang-bang mode for the chamber heater and set PWM limit
      M141 H2 ; map chamber to heater 2
      M143 H2 S75 ; set temperature limit for Chamber to 75C
      M106 P2 S0 H-1 ; set fan 2 value. Thermostatic control is turned off
        As you are using RRF3 you can just create a sensor. No heater needed.
        • davidvh86
          yes i am. so would i replace h# with s3
            dc42 administrators @davidvh86 last edited by
            @davidvh86 said in Creating thermostatic fan without heater:
            The parameter in M106 is still H but its value in RRF3 is a sensor number, not a heater number.
