    third party sd card reader
    • tekstyleundefined
      tekstyle
      i am constraint by the length of the ribbon cable connecting the paneldue. since the 4 pin connector has no length limit, i was hoping to just connect that to the paneldue and have a sd card to 10 pin ribbon cable to the duet2wifi board. is this possible? i assume i will need to find a sd card breakout board?
        Yes you can do that. The length of cable between the SD card socket and the Duet should not exceed 300mm.
        tekstyleundefined 1 Reply Last reply Reply Quote 0
        • tekstyleundefined
          tekstyle @dc42
          @dc42 got it. thank you!
