UNSOLVED Duet 3 + Tool board stops mid-print and reports 100% complete
9/6/2020, 4:14:49 PM M122 B121 Diagnostics for board 121: Board TOOL1LC firmware 3.1.0 (2020-05-15b1) Never used RAM 8.5Kb, max stack 584b HEAT 1048 CanAsync 1392 CanRecv 1380 TMC 188 AIN 524 MAIN 2308 Last reset 00:14:50 ago, cause: power up Driver 0: standstill, SG min/max 0/20, read errors 0, write errors 0, ifcount 13, reads 49738, writes 13, timeouts 1, DMA errors 0, failedOp 0x80 Moves scheduled 25, completed 25, hiccups 0 VIN: 24.2V MCU temperature: min 48.6C, current 62.2C, max 62.3C Ticks since heat task active 174, ADC conversions started 889143, completed 889142, timed out 0 Last sensors broadcast 00000002 found 1 177 ticks ago Free CAN buffers: 36 NVM user row b1d088a9 fffff8bb 20002a18 b TSENS 001847 GAIN 014ffc OFFS 00273f CAL 1f2a 9/6/2020, 4:14:32 PM M122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-956L2-G43S8-6JKDL-3SJ6L-1802G Used output buffers: 1 of 40 (11 max) === RTOS === Static ram: 154604 Dynamic ram: 162928 of which 60 recycled Exception stack ram used: 520 Never used ram: 75104 Tasks: NETWORK(ready,1972) HEAT(blocked,1188) CanReceiv(suspended,3388) CanSender(suspended,1428) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,2672) IDLE(ready,76) Owned mutexes: === Platform === Last reset 00:14:33 ago, cause: power up Last software reset at 2020-09-06 20:50, reason: User, spinning module LinuxInterface, available RAM 75624 bytes (slot 1) Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN Error status: 0 MCU temperature: min 38.0, current 43.6, max 43.7 Supply voltage: min 23.8, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.2, max 12.3, under voltage events: 0 Driver 0: standstill, reads 2465, writes 20 timeouts 0, SG min/max 0/420 Driver 1: standstill, reads 2465, writes 20 timeouts 0, SG min/max 0/1015 Driver 2: standstill, reads 2466, writes 20 timeouts 0, SG min/max 0/1013 Driver 3: standstill, reads 2466, writes 20 timeouts 0, SG min/max 0/999 Driver 4: standstill, reads 2466, writes 20 timeouts 0, SG min/max 0/1005 Driver 5: standstill, reads 2467, writes 20 timeouts 0, SG min/max 0/492 Date/time: 2020-09-06 21:14:31 Slowest loop: 8.49ms; fastest: 0.13ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 375, MinFreeDm: 367, MaxWait: 416505ms Bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves: 482, completed moves: 482, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 === GCodes === Segments left: 0 Movement lock held by null HTTP* is ready with "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon* is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 0.83ms; fastest: 0.01ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions HTTP sessions: 0 of 8 - Ethernet - State: disabled Error counts: 0 0 0 0 0 Socket states: 0 0 0 0 0 0 0 0 === CAN === Messages sent 4528, longest wait 3ms for type 6012 === Linux interface === State: 0, failed transfers: 0 Last transfer: 23ms ago RX/TX seq numbers: 25913/25914 SPI underruns 0, overruns 0 Number of disconnects: 1 Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.1.1 File: Buffered code: G1 X247.109 Y320.100 E11.7503 Buffered code: G1 X245.109 Y318.100 E11.8378 Buffered code: G1 X178.109 Y318.100 E13.9103 Buffered code: G1 X171.900 Y311.891 E14.1819 Buffered code: G1 X171.900 Y268.888 E15.5120 Buffered code: G1 X168.904 Y265.893 E15.6431 Buffered code: G1 X168.899 Y249.127 E16.1617 Buffered code: G1 X171.900 Y246.117 E16.2932 Buffered code: G1 X171.900 Y203.109 E17.6235 Buffered code: G1 X178.109 Y196.900 E17.8951 Buffered code: G1 X178.275 Y197.300 F18000 Buffered code: G92 E0.0000 Buffered code: G1 X245.275 Y197.300 E2.0724 F1800 Buffered code: G1 X247.275 Y195.300 E2.1599 Buffered code: G1 X267.725 Y195.300 E2.7925 Buffered code: G1 X269.725 Y197.300 E2.8800 Buffered code: G1 X336.725 Y197.300 E4.9524 Buffered code: G1 X342.700 Y203.275 E5.2138 Buffered code: G1 X342.700 Y246.275 E6.5439 Buffered code: G1 X345.700 Y249.275 E6.6751 Buffered code: G1 X345.700 Y265.725 E7.1839 Buffered code: G1 X342.700 Y268.725 E7.3152 Buffered code: G1 X342.700 Y311.725 E8.6452 Buffered code: G1 X336.725 Y317.700 E8.9066 Buffered code: G1 X269.725 Y317.700 E10.9790 Buffered code: G1 X267.725 Y319.700 E11.0665 Buffered code: G1 X247.275 Y319.700 E11.6991 Buffered code: G1 X245.275 Y317.700 E11.7866 Buffered code: G1 X178.275 Y317.700 E13.8590 Buffered code: G1 X172.300 Y311.725 E14.1204 Buffered code: G1 X172.300 Y268.722 E15.4505 Buffered code: G1 X169.304 Y265.727 E15.5816 ==> 1524 bytes Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 15.00 File /opt/dsf/sd/gcodes/test-fixed.gcode is selected, processing
Can you provide the M122 for the mainboard as well?
And can you try enabling the debug mode?
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Monitoring_optional
Does this happen with every print?
Can you share the gcode file as well?
@Phaedrux said in Duet 3 + Tool board stops mid-print and reports 100% complete:
M122 is for both, main board starts at line 17
@evomotors said in Duet 3 + Tool board stops mid-print and reports 100% complete:
It doesn't happens on every print, the same gcode file did work when I started printing again from the beginning. It happened to me 3 or 4 times since I upgraded to Duet board few weeks ago.
I will enable diagnostics
