    Solved Duet 3 homing reset error
    • gt40
      gt40 last edited by gt40
      Hello everyone,
      I have been printing with my Duet 3 powered corexy for a couple of weeks and now I am having a "loop" where when I try to home, it resets to an unhomed state upon homing. If you do a single axis it does the same thing and flashes homed and then resets to unhomed. No errors on the console reported.
      Short video of the homing issue:
      https://vimeo.com/manage/456388566/general
      Here is the M122:
      9/9/2020, 6:07:29 PM m122
      RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode)
      Board ID: 08DJM-956L2-G43S4-6J9F2-3SJ6M-1A6UG
      Used output buffers: 1 of 40 (13 max)
      Static ram: 154604
      Dynamic ram: 163388 of which 20 recycled
      Exception stack ram used: 528
      Never used ram: 74676
      Tasks: NETWORK(ready,1968) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1384) CanClock(blocked,1436) TMC(blocked,60) MAIN(running,4544) IDLE(ready,76)
      Owned mutexes:
      Last reset 00:42:06 ago, cause: software
      Last software reset at 2020-09-10 01:25, reason: User, spinning module LinuxInterface, available RAM 74788 bytes (slot 2)
      Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task MAIN
      Error status: 0
      MCU temperature: min 40.2, current 40.3, max 40.5
      Supply voltage: min 23.8, current 24.0, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
      Driver 0: standstill, reads 40080, writes 4 timeouts 0, SG min/max 0/638
      Driver 1: standstill, reads 40080, writes 4 timeouts 0, SG min/max 0/646
      Driver 2: standstill, reads 40080, writes 4 timeouts 0, SG min/max 0/861
      Driver 3: standstill, reads 40083, writes 0 timeouts 0, SG min/max not available
      Driver 4: standstill, reads 40084, writes 0 timeouts 0, SG min/max not available
      Driver 5: standstill, reads 40083, writes 0 timeouts 0, SG min/max not available
      Date/time: 2020-09-10 02:07:26
      Slowest loop: 5.28ms; fastest: 0.14ms
      === Storage ===
      Free file entries: 10
      Hiccups: 0(0), FreeDm: 375, MinFreeDm: 373, MaxWait: 49201ms
      === MainDDARing ===
      Scheduled moves: 90, completed moves: 90, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
      === AuxDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
      Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 3 -1 -1 -1
      Segments left: 0
      Movement lock held by null
      HTTP* is ready with "M122" in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon* is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 1.97ms; fastest: 0.01ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
      HTTP sessions: 0 of 8
      • Ethernet -
        State: disabled
        Error counts: 0 0 0 0 0
        === CAN ===
        Messages sent 309, longest wait 0ms for type 0
        === Linux interface ===
        State: 0, failed transfers: 0
        Last transfer: 19ms ago
        RX/TX seq numbers: 14684/14686
        SPI underruns 0, overruns 0
        Number of disconnects: 0
        Buffer RX/TX: 0/0-0
        === Duet Control Server ===
        Duet Control Server v3.1.1
        Code buffer space: 4096
        Configured SPI speed: 8000000 Hz
        Full transfers per second: 31.97
      Any suggestions would be appreciated.
      Mark
        Your video link goes to a log in page. Do you have a public link?
        Can you post your config.g and homing files?
        • gt40
          Sorry about the bad link. Here is the correct link for the video:
          https://vimeo.com/456388566
          config file:
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Thu Aug 13 2020 09:44:43 GMT-0700 (Pacific Daylight Time)
          M550 P"Duet 3" ; set printer name
          M669 K1 ; select CoreXY mode
          M569 P0.1 S1 ; physical drive 0.1 goes forwards
          M569 P0.2 S0 ; physical drive 0.2 goes backwards
          M569 P0.3 S1 ; physical drive 0.3 goes forwards
          M569 P0.4 S1 ; physical drive 0.4 goes forwards
          M584 X0.0 Y0.1 Z0.2 E0.3:0.4 ; set drive mapping
          M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
          M92 X160.00 Y160.00 Z640.00 E822.67:822.67 ; set steps per mm
          M566 X9000.00 Y9000.00 Z300.00 E3600.00:3600.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X12000.00 Y12000.00 Z500.00 E4800.00:4800.00 ; set maximum speeds (mm/min)
          M201 X9000.00 Y9000.00 Z50.00 E80.00:80.00 ; set accelerations (mm/s^2)
          M906 X2200 Y2200 Z3200 E1800:1800 I0 ; set motor currents (mA) and motor idle factor in per cent
          M84 S.5 ; Set idle timeout
          M208 X450 Y280 Z320 S0 ; set axis maxima
          M574 X2 S1 P"io1.in" ; configure active-high endstop for high end on X via pin io1.in
          M574 Y1 S1 P"!^io2.in" ; configure active-high endstop for low end on Y via pin !^io2.in
          M574 Z1 S2 ; configure Z-probe endstop for low end on Z
          M558 P5 C"^!io3.in" H2 F150 T1800 ; set Z probe type to switch and the dive height + speeds
          M558 H2 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
          G31 P1000 X0 Y0 Z0.59 ; set Z probe trigger value, offset and trigger height
          M557 X0:450 Y20:280 S20 ; define mesh grid
          M308 S0 P"temp0" Y"pt1000" R2200 ; configure sensor 0 as PT1000 on pin temp0
          M143 H0 S170 ; set temperature limit for heater 0 to 170C
          M308 S1 P"temp1" Y"pt1000" R2200 ; configure sensor 1 as PT1000 on pin temp1
          M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
          M143 H1 S450 ; set temperature limit for heater 1 to 450C
          M308 S2 P"temp2" Y"pt1000" R2200 ; configure sensor 1 as PT1000 on pin temp1
          M950 H2 C"out2" T2 ; create nozzle heater output on out1 and map it to sensor 2
          M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
          M143 H2 S450 ; set temperature limit for heater 2 to 450C
          M308 S3 P"temp3" Y"pt1000" R2200 ; configure sensor 3 as PT1000 on pin temp3
          M950 H3 C"out9" T3 ; create bed heater output on out9 and map it to sensor 3
          M141 H3 ; Define heater h3 as chamber heater
          M301 H3 P-1 ; Disable PID settings to use bang-bang
          M143 H3 S150 ; set temperature limit for heater 3 to 150C
          ;M950 F0 C"out8" ; create fan 0 on pin out8 and set its frequency
          ;M106 P0 C"fan + lights" S1 H-1 ; set fan 0 name and value. Thermostatic control is turned off
          ;M563 P0 D0 H0 ; tool 0 uses extruder 0, heater 1 (and fan 0)
          ;M563 P1 D1 H1 ; tool 0 uses extruder 0, heater 1 (and fan 0)
          M563 P0 S"Mosquito Main 0" D0 H1 F0 ; define tool 0
          M563 P1 S"Mosquito Support 1" D1 H2 F0 ; define tool 1
          G10 P1 X16.150 Y2.15 Z0 ; set tool 1 axis offsets
          G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
          M501 ; enable config override
          M572 D0 S0.4 ; enable pressure advance
          M572 D1 S0.4 ; enable pressure advance
            Phaedrux Moderator @gt40 last edited by
            @gt40 said in Duet 3 homing reset error:
            Your idle timeout seems to be set at half a second...
            • gt40
              gt40 last edited by
              Thank you very much for your help. I changed the M84 in the config.g file to 20 and all is well. Please mark this resolved and again, a big thanks for the quick response.
              Mark
