    Web Control Look and feel
    Duet Web Control
    2.4k
    • PR1ORundefined
      PR1OR @Veti
      @Veti So it connects to the IP but when i click to connect to the board it just doesnt do anything. It also shows like before where the axis bit looks odd again. Saying all this i get this screen fairly frequently on firefox but after a few refreshes it normally updates, this doesnt happen in chrome or safari
      • Vetiundefined
        Veti
        that is still not the web ui for version 3.1.1
        PR1ORundefined 1 Reply Last reply Reply Quote 0
        • PR1ORundefined
          PR1OR @Veti
          @Veti i have fully updates to 3.1.1 now is there a g code i can input to tell me what the ui version is?
          Vetiundefined 1 Reply Last reply Reply Quote 0
          • Vetiundefined
            Veti @PR1OR
            @PR1OR
            take out the sd card. mount it in your computer.
            delete all files in the www folder
            unzip the files from https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/DuetWebControl-SD-3.1.1.zip into the www folder
            • PR1ORundefined
              PR1OR @Veti
              @Veti did this and now my wifi LED isnt lighting at all and i cant connect :s
              • PR1ORundefined
                PR1OR @PR1OR
                @PR1OR dont worry i did it wrong. overwrote all the files by accident.
                I have fixed that now
                UI now looks like this
                • Vetiundefined
                  Veti
                  that looks correct. and all the values get displayed.
                    You can verify the DWC version in the General tab on the left side but that now looks correct for 3.1.1.
                    You should now be able to upload the config.zip to the system tab.
                    • PR1ORundefined
                      PR1OR @Phaedrux
                      @Phaedrux @Veti
                      Thanks both i have managed to upload the Config now. However i have a feeling the person i got the zip off may have to many in the same file so now im not sure what should and should be there. Can you confirm this is right?
                      https://youtu.be/ioaC-JRMzCQhttps://youtu.be/ioaC-JRMzCQ
                        Ok it looks like you have the entire contents of the /www folder in your /sys folder.
                        The sys folder should have the .bin files for the firmware and .g files for the config. Everything else with a .gz should be removed.
                        • PR1ORundefined
                          PR1OR @Phaedrux
                          @Phaedrux said in Web Control Look and feel:
                          So should i unplug the SD card and sort in to this?
                          .bin = sys folder
                          .g = gcodes
                          .gz = delete
                          • PR1ORundefined
                            PR1OR @PR1OR
                            @PR1OR
                            also delete the .json?
                              No you can do it right from the web interface. Put a checkmark next to the .gz files and then right click and delete.
                              Leave the .g files in the /sys folder. Those are the configuration files you would edit, particularly config.g
                                No leave the .json file. It's generated by the web configurator. It's got a list of all your settings that you can use to load up your configuration in the tool again if you wanted.
                                config.g.bak is a backup of the config.g file that gets updated every time you edit it so you can go back one version if you make a mistake.
                                • PR1ORundefined
                                  PR1OR @Phaedrux
                                  i
                                  ok perfect thank you. Thats all done. Now to sort the wiring out (rofl)
                                  Im sure we will chat again haha but really appreciate your help!!
