    DWC3 Webserver Documentation
    Duet Web Control
    • hauschkaundefined
      hauschka
      Hi All,
      I'm currently looking for a documentation of the DWC3, more precisely the available HTTP/json requests?
      Under DWC2, I was able to query machine info through these commands.
      While I can now get the machine's info through /machine/status, I'm not sure how to upload a gcode file, send + execute single Gcode commands, download files, etc...
      I couldn't find the documentation where the new "architecture" is described.
      I'm using these commands to control my printer through a custom web interface hosted somewhere else, I guess communicating through DWC is the way to go here, right?
      Best,
      -h
      Chrissundefined 1 Reply Last reply Reply Quote 0
      • Chrissundefined
        Chriss @hauschka
        @hauschka
        Mabe here:
        https://duet3d.dozuki.com/Wiki/Object_Model_of_RepRapFirmware
        https://duet3d.github.io/DuetSoftwareFramework/api/DuetAPI.Machine.MachineModel.html
        • hauschkaundefined
          hauschka
          Hi Chriss,
          Thanks for the 2 links.
          I still don't quite understand how I would send for example a .gcode file.
          The 1st link mentions rr_ commands.
          Is the rr_model HTTP command still working under RRF3?
          I was under the impression this was deprecated?
          Best,
          -h
          Chrissundefined gtj0undefined 2 Replies Last reply Reply Quote 0
          • Chrissundefined
            Chriss @hauschka
            @hauschka
            Sorry, I do not have more than the two links. My plan is to write the metrics from the board to a influxdb to graph them. The forum pointed me to this two URLs. That is all I know so far. My project is still in planing, sorry.
            I'm sure that somebody with more know how will jump in here.
            Cheers, Chriss
            • gtj0undefined
              gtj0 @hauschka
              @hauschka Check out the README for https://github.com/Duet3D/DuetSoftwareFramework
              It has a list of all the calls you can make in the new environment.
              hauschkaundefined 1 Reply Last reply Reply Quote 2
              • hauschkaundefined
                hauschka @gtj0
                @gtj0 said in DWC3 Webserver Documentation:
                You're my hero!
                Thanks! That was exactly what I was looking for. No clue how I missed it!
                Thans a lot gtj0
