    state.status and filament runout?
    Gcode meta commands
    filament runout gcode status
    861
    • mitchundefined
      mitch
      Is it possible to determine if a macro is being run during a print versus being executed directly by the user?
      Background:
      User commanded filament loading/unloaded:
      I have a macro for unloading and loading filament. The filament files themselves are pretty simple which makes it easier to create new filaments. Each will call a common file so that I don't have to reproduce that code or fix it in more places than one.
      PETG Example:
      ; 0:/filaments/PETG/load.g
      ; Macro used to load PETG, Called by the M701 S”PETG” command
      ; Custom temp for PETG here
      M80				; Turn on PSU
      T0				; Activate Hotend
      M702			; Unload previous material
      M291 R"Filament Handling" P"Heating nozzle for PETG, please wait." S0
      M109 S250			; set temp to 250c and wait
      ; Finish Common Steps
      M98 P/macros/general/filament/Load_Common
      ; 0:/filaments/PETG/unload.g
      ; Macro used to unload PETG, Called by the M702 command
      M80				; Turn on PSU
      M98 P/macros/general/filament/UnLoad_Common
      The common files:
      ; 0:/macros/general/filament/Load_Common
      ; Common Macro used to load filament, Called by the M701 S”???” command
      ; Each filament in /filaments/XXX/load.g will set the custom extruder temp then call this common macro
      ; Determine if we need to Home first or not
      if state.status != "processing"	;If a print is NOT in progress
      	if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
      		G28		; Home all axes
      ; Filament is currently loaded
      if sensors.filamentMonitors[0].filamentPresent = true
          M291 P"Retracting filament..." R"Unloading Filament" T5 ; Display another message
          G1 E-50 F3000 		; Retract 50mm of filament at 3000mm/min
      M400				; Wait for all moves to finish
      ; Position the bed
      G90            		; absolute positioning
      G1 X0 Y0 Z50 F6000 	; go to X=0 Y=0 Z=50
      M98 P/macros/Tunes/Attention.g
      M291 P"Insert filament and then click OK to start feeding" R"Proceed?" S3
      M291 P"Feeding filament..." R"Loading Filament" T5 ; Display new message
      G1 E60 F600 ; Feed 60mm of filament at 600mm/min
      M291 P"Wipe off filament then click OK to complete feeding" R"Proceed?" S3
      M291 P"Retracting 2mm of filament..." R" Filament" T5 ; Display another message
      G1 E-2 F300 		; Retract 2mm of filament at 300mm/min
      	G10 S0 ; Turn off the heaters
      M98 P/macros/Tunes/LuckyTune.g
      M291 R"Filament Handling" P"Loading Complete." T5
      ; 0:/macros/general/filament/Unload_Common
      ; Common Macro used to load filament, Called by the M702 command
      ; Each filament in /filaments/XXX/unload.g will set the custom extruder temp then call this common macro
      		G28		; Home all axes
          M291 P"Ready for filament unloading. Gently pull filament out and press OK." R"Filament Handling" S2
      M291 R"Filament Handling" P"Unloading Complete." T5
      Now for the issue:
      I am testing the filament run-out use case. My filament monitor also has the micro-switch enabled. In the event that a run-out occurs it looks like the pause.g is being called correctly, which in turn calls the filament-change.g correctly. The issue is that when this occurs because of a run-out I DO NOT want the heaters turned off. I attempted to use state.status and I expected the call to return processing when printing and busy when executing a macro. I am obviously incorrect with that assumption because my heaters were disabled when this was run in a filament-out condition.
      ; pause.g
      ; called when a print from SD card is paused or filament out is detected
      ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Feb 09 2020 08:41:29 GMT-0600 (Central Standard Time)
      M83            ; relative extruder moves
      G1 E-4 F3600   ; retract 4mm of filament
      G91            ; relative positioning
      G1 Z5 F360     ; lift Z by 5mm
      G1 X0 Y0 F6000 ; go to X=0 Y=0
      if sensors.filamentMonitors[0].filamentPresent = false          ; Filament is absent, we must have run out
           M291 S1 R"No filament detected." P"Filament Handling." T10
           M98 P"0:/sys/filament-change.g"                            ; Call filament-change.g
           G1 R1 X0 Y0 Z5 F6000                                       ; go to 5mm above position of the last print move
           G1 R1 X0 Y0                                                ; go back to the last print move
           G1 E4 F3600                                                ; extrude 4mm of filament
           M24				                                        ; Resume Print
      ; 0:/sys/filament-change.g
      ; Macro used to change filament during prints
      M291 P"Filament change in progress." R"Filament Change" T5 ; Display message
      ; Move extruder to loading position
      ; if a filament was loaded but we just ran out, load some more
      if move.extruders[0].filament != "" then
           M98 P{"0:/filaments/" ^ move.extruders[0].filament ^ "/load.g"}  ; Reload the same type of filament
           ;G1 R1 X0 Y0 Z5 F6000 ; go to 5mm above position of the last print move
           ;M83                  ; relative extruder moves to resume printing
      else
           M291 P"Use macros to load the desired filament." R"Filament Handling" S3
      ; resume.g
      ; called before a print from SD card is resumed
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @mitch
        @mitch
        state.status will return "busy" when you run a macro.
        However in your case it's possible for it to return "printing" or maybe "processing" depending on where it is during a print. It might also return "busy" during a print.
        I'm not sure on the last.
        Maybe you should check whether a file is loaded
        if job.file.fileName == null
        	echo "No file selected"
               ;Turn off heaters etc
        else
        	echo "Printing " ^ job.file.fileName
                ; Do whatever you want here
        mitchundefined 1 Reply Last reply Reply Quote 1
        • mitchundefined
          mitch @OwenD
          @OwenD great suggestion. Exactly what I was looking for.
          • Kolbiundefined
            Kolbi
            @OwenD That's a great way to solve it! Checking if a file is currently loaded didn't occur to me as a way to solve the question.
            @mitch I went slightly off the deep-end and was thinking of using variables(or closest to it) to solve it as such:
            Load_Common:
            Lines: 33-35 Turn off heaters if not in Processing state.
            Unload_Common:
            Lines: 18-20 Turn off heaters in not in Processing state.
            filament-change.g calls load or unload
            In config.g (to set up existence and initial state):
            M950 F5 C"duex.fan5"
            M106 P5 C"Variable1-A"
            Logic example for pause.g:
            M106 P5 C"Variable1-B" Added before line 13
            Logic example for Load_Common.g:
            If fans[5].name = "Variable1-A" then
            Else
            mitchundefined 1 Reply Last reply Reply Quote 0
            • mitchundefined
              mitch @Kolbi
              @Kolbi That is why I like this forum so much. Lots of quick responses and several ways to skin the cat. I think I am going to go with the file loaded as it seems to be the easiest way to solve this one.
              Although, this is really all your fault because the macros you have on your github sparked the inspiration to dig into some of this.
              BLtouch assisted bed leveling macro:
              The next idea I had was to look at a way to make a BLtouch bed leveling assistant macro. The idea would be to have the bltouch probe go to each leveling point so the user just adjusts the bed level slowly until the BL touch activates. I figure doing this in 3 or 4 passes to include the center point should make it a much shorter process that the trial and error of leveling and re-running the entire G29 to figure out where you want to tweak and re-run.
              Thanks for the help.
              dc42undefined 1 Reply Last reply Reply Quote 1
              • Kolbiundefined
                Kolbi
                @mitch Yup, I'd go with the file check route also.
                Glad to hear I sparked inspiration! The craftbot using something like what you're talking about with assisted bed leveling - I just saw that here: https://www.youtube.com/watch?v=eItOpffE3ts
                • mitchundefined
                  mitch @Kolbi
                  @Kolbi yes, at around 1:00:00 in that video is exactly what I was thinking. Should be some kind of guided level assistance with the BL touch. I searched around the forum and I haven't see anything like that yet for the Duet but I would be shocked if someone hasn't played with yet before. If I have time tomorrow I might give it a start. Will create a new thread if I can make some headway on it and maybe collaboratively we can come up with something.
                  Here it is in more detail:
                  https://youtu.be/YOVBBA4vJHE
                  • Kolbiundefined
                    Kolbi
                    Seems like it should be possible but the biggest hurdle would be that variables are not available for use. But... Could do something like this:
                    Execute this to probe and save Z position information:
                    G30 S-1
                    G60 S0 ; Save to slot 0 (S0,1,2,3,4,5)
                    G1 Z5
                    Recall the z info with:
                    ; Read Z position (coords[2]) from slot 0 (restorePoints[0], restorePoints[1],....)
                    echo "Saved Z position for slot 0: " ^ state.restorePoints[0].coords[2] ^ "."
                    Previously I've used this method for slots 0,1,2,3,4,5 with no issues. I myself don't have an adjustable bed but of course, I'd give what assistance I can.
                      dc42 administrators @mitch
                      @mitch said in state.status and filament runout?:
                      See https://duet3d.dozuki.com/Wiki/Using_the_manual_bed_levelling_assistant.
                      • mitchundefined
                        mitch @dc42
                        @dc42 thank you. This is very helpful. I will give it a try. It seems the assistant you have asks the user to adjust per a given thread pitch. I do like the craftbot method of just continuously probing and letting the use make micro adjustments to see how close they are getting to the desired positions.
                        Perhaps once we have SBC capability on the Duet2 we can make more elaborate wizards and guided assistants.
