    No Filament Sensor Feedback
    Filament Monitor
    • DomMilan
      DomMilan last edited by
      Good day,
      I have installed the IR Duet F sensor on my Duet 2. Can't seem to get feedback on the thing using M591 D0 or print functionally. It is installed right before a Titan extruder. I have extrusion but it does not seem to pick it up.
      This is in my config
      ;M591 D0 P3 C3 S1 R70:130 L24.8 E8.0 ; Duet3D rotating magnet sensor for extruder drive 0 is connected to E0 endstop input, enabled, sensitivity 24.8mm.rev, 70% to 130% tolerance, 3mm detection length
      ;M591 D0 ; display filament sensor parameters for extruder drive 0
      Thank you!
      • T3P3Tony
        T3P3Tony administrators @DomMilan last edited by
        @DomMilan do you have the
        or no ";"
        Because with the ":" that line is a comment in your config.g and not applied.
        www.duet3d.com
        DomMilan 1 Reply Last reply Reply Quote 0
        • DomMilan
          I had it without. Disabled because it was not working.
          • DomMilan
            DomMilan @T3P3Tony last edited by
            @T3P3Tony Following up on this as I am still a bit confused with this setup. I am running Bigtrees smart F sensor on many of my marlin machines, which I believe follows the same concept of the duet one.
            • BoA
              BoA last edited by BoA
              Which firmware version?
              In RRF3 C has different value - more like M591 D0 P3 C"e0stop"
