    CoreXY + duet2 wifi
    • msource
      msource last edited by
      Hello Guys,
      I have a Two Trees Sapphire Pro and I want to change the MKS Robin Nano board to a duet2 wifi.
      Some changes:
      PSU: Meanwell 500W 24V
      4 motors 0.9 Angle 1.68A
      • 3 x High Torque (XYZ)
      • 1 x Compact but powerful (E)
      Hotend: E3D V6
      Bed: Aliminum cut plate 6mm + Silicone heatbed 200W 24V.
      BLTouch (Trianglelab clone: 3DTouch)
      Question:
      • What will be the correct current value for the motors for each
      • What will be the correct esteps
      • What will be the correct Feedrate
      • What will be the correct Max Acceleration
      I'm moving from Marlin to duet2 wifi.
      The values I have from stock 1.8 angle motors.
      Also, the connection/configuration of BLTouch will be really appreciated
      Sincerely,
      Marcos Fernandes
      Veti 1 Reply Last reply Reply Quote 0
      • Veti
        Veti @msource last edited by Veti
        @msource said in CoreXY + duet2 wifi:
        if you switch to 0.9 its 2x the steps
        1.68A Motors go with 75% the current
        go with the values from marlin for now and do testprints afterwards increasing the acceleration and see if you like the result or not.
        use https://configtool.reprapfirmware.org/Start to create a config for your printer.
          For the Z axis motor you may want to stick with a 1.8 degree motor and choose a lead screw with a finer lead, for example 2mm. That can give you more torque and holding power for a heavy bed that moves in Z and still gives a very high Z axis resolution.
          Also, if you're only using 1 motor for Z, is it a cantilevered bed, or is it a single motor belted to the lead screws?
          steps per mm formulas:
          xy_steps_per_mm = (motor_steps_per_rev ∗ driver_microstep) / (belt_pitch ∗ pulley_number_of_teeth)
          Z_steps_per_mm = (motor_steps_per_rev * driver_microstep) / screw_lead
          e_steps_per_mm = (motor_steps_per_rev * driver_microstep) * (big_gear_teeth / small_gear_teeth) / (hob_effective_diameter * pi)
          BlTouch: https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
          If you're new to RRF I suggest going with RRF3 to start with.
          You can get a basic config here: https://configtool.reprapfirmware.org/Start
