    Duet3 Stuck in spin loop
    147
    • projectR3D
      projectR3D last edited by
      We have been testing a new unit with Duet3 with SBC (Pi3b+), we have run into a couple of errors. The first would be a full system hang after a print cancel and then hitting reprint. Since a print has been canceled the temp is still high but it will never start printing. It will sit at 0.0% and nothing will respond, if you hit a button in the web interface it will just spin. The second more common (only about 5% of the time) issue is a disconnect and restart of the system upon an "Upload and Print" process. So far its mostly been with S3D files.
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
      Board ID: 08DJM-956L2-G43S8-6J1FJ-3S46K-9S26D
      Used output buffers: 1 of 40 (11 max)
      Static ram: 154604
      Dynamic ram: 162900 of which 64 recycled
      Exception stack ram used: 528
      Never used ram: 75120
      Tasks: NETWORK(ready,1980) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1432) CanClock(blocked,1436) TMC(blocked,204) MAIN(running,5016) IDLE(ready,76)
      Owned mutexes:
      Last reset 00:05:11 ago, cause: software
      Last software reset at 2020-09-15 02:15, reason: Stuck in spin loop, spinning module GCodes, available RAM 74976 bytes (slot 1)
      Software reset code 0x4083 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a80f BFAR 0x00000000 SP 0x20417b14 Task MAIN
      Stack: 00000034 00427e86 010f0000 00000000 40a25c00 42595364 bf8f81ee 42c80001 3d9096e1 00000000 3e1096e1
      Error status: 0
      MCU temperature: min 52.8, current 52.8, max 54.4
      Supply voltage: min 24.2, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.3, current 12.4, max 12.4, under voltage events: 0
      Driver 0: standstill, reads 10631, writes 17 timeouts 0, SG min/max 0/158
      Driver 1: standstill, reads 10632, writes 17 timeouts 0, SG min/max 0/184
      Driver 2: standstill, reads 10633, writes 17 timeouts 0, SG min/max 0/145
      Driver 3: standstill, reads 10633, writes 17 timeouts 0, SG min/max 0/146
      Driver 4: standstill, reads 10634, writes 17 timeouts 0, SG min/max 0/141
      Driver 5: standstill, reads 10637, writes 14 timeouts 0, SG min/max 0/0
      Date/time: 2020-09-15 02:20:50
      Slowest loop: 5.38ms; fastest: 0.15ms
      === Storage ===
      Free file entries: 10
      Hiccups: 0(0), FreeDm: 375, MinFreeDm: 373, MaxWait: 270570ms
      === MainDDARing ===
      Scheduled moves: 13, completed moves: 13, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      === AuxDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP* is ready with "M122" in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon* is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 1.10ms; fastest: 0.01ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
      HTTP sessions: 0 of 8
      - Ethernet -
      State: disabled
      Error counts: 0 0 0 0 0
      === CAN ===
      Messages sent 1247, longest wait 0ms for type 0
      === Linux interface ===
      State: 0, failed transfers: 0
      Last transfer: 17ms ago
      RX/TX seq numbers: 44715/10150
      SPI underruns 0, overruns 0
      Number of disconnects: 0
      Buffer RX/TX: 0/0-0
      === Duet Control Server ===
      Duet Control Server v3.1.1
      Code buffer space: 4096
      Configured SPI speed: 8000000 Hz
      Full transfers per second: 32.14
      G21						;Work in millimetres
      G90						;Send absolute coordinates...
      M83						;...but relative extruder moves
      ; Axis and motor configuration
      M569 P0 S1					;Drive 0 X / Rear
      M569 P1 S1					;Drive 1 Y / Front
      M569 P2 S1					;Drive 2 Z Front Left
      M569 P3 S1					;Drive 3 Z Rear Left
      M569 P4 S1					;Drive 4 Z Right
      M569 P5 S0					;Drive 5 Extruder
      M667 S1						;corexy mode
      M584 X0 Y1 Z2:3:4 E5			; Map X to drive 0 Y to drive 1, Z to drives 2, 3, 4, and E to drive 5
      ;Leadscrew locations
      M671 X-38:-38:340  Y62.5:247.5:139 S7.5		;X -38, -38, 340
      M350 X16 Y16 Z16 E16 I1				;set 16x microstepping for axes with interpolation
      M906 X1400 Y1400 Z1200 E1500 I60			;Set motor currents (mA)
      M201 X2000 Y2000 Z100 E1500			;Accelerations (mm/s^2)
      M203 X24000 Y24000 Z900 E3600			;Maximum speeds (mm/min) was Z1800 tr8*4
      M566 X1000 Y1000 Z100 E1500			;Maximum jerk speeds mm/minute E60 Z60
      M208 X310 Y300 Z435				;set axis maxima and high homing switch positions (adjust to suit your machine)
      M208 X0 Y0 Z-2 S1				;set axis minima and low homing switch positions (adjust to make X=0 and Y=0 the edges of the bed)
      ;M92 X200 Y200 Z1600 E819.5			;steps/mm
      M92 X200 Y200 Z800 E830			;steps/mm 0.9 z
      ; End Stops
      M574 X1 S1! P"io3.in"				;Map the X endstop to io3.in
      M574 Y2 S1! P"io1.in"				;May the Y endstop to io1.in
      ; Thermistors
      M308 S0 P"temp0" Y"thermistor" A"bed_heat" T100000 B4240 H0 L0 		;Bed thermistor - duet 3, connected to temp0
      M308 S1 P"temp1" Y"thermistor" A"e0_heat" T100000 B4725 C7.06e-8 H0 L0	;duet3 e3d
      ;M308 S1 P"temp1" Y"thermistor" A"e0_heat" T500000 B4723 C1.196220e-7	;duet3 slice
      ;Define Heaters
      M950 H0 C"out0" T0				;Bed heater is on out0
      M950 H1 C"out1" T1				;Hotend heater is on out1
      M307 H0 A90.0 C700.0 D10.0 S1.00 B1 		;Keenovo duet 3 configuration
      M307 H1 A548.8 C298.6 D4.6 S1.00 B0 		;Hotend  duet 3 configuration
      M570 S360					;Hot end may be a little slow to heat up so allow it 180 seconds
      M143 S285					;Set max hotend temperature
      M950 F0 C"out4"					;Hotend fan on "out4" connector
      M106 P0 S255 H1 T50 				;enable thermostatic mode for hotend fan
      M950 F1 C"out5"					;Layer fan on "out5" connector
      M106 P1 S0 					;Layer Fan
      M950 F2 C"out6"					;Layer fan on "out6" connector
      M106 P2 S0 					;Layer Fan
      ; Tool definitions
      M563 P0 D0 H1 F1:2                        	;Define tool 0
      G10 P0 S0 R0                        		;Set tool 0 operating and standby temperatures
      ;BLTouch
      ;M558 P9 C"io7.in" H5 R1 F50 T6000 A5 S0.02 B1	;define the bltouch input on io8.in
      ;M950 S0 C"!io7.out"				;define the bltouch servo on io8.out"
      M558 P5 C"!io7.in" I0 H10 F180 T3600 ; set Z probe type to bltouch and the dive height + speeds
      G31 X-10 Y66 Z1.9 P25
      M557 X66:250 Y66:250 S184
      M501
      M140 H0
      T0						;select first hot end
      Any help would be greatly appreciated, if you have any questions please let me know
        What do you have in your pause.g and cancel.g files?
        Can you switch to standalone mode to test if it behaves the same way?
        • projectR3D
          Pause.g
          ; pause.g
          ; called when a print from SD card is paused
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Feb 02 2020 20:26:36 GMT-0600 (Central Standard Time)
          M83            ; relative extruder moves
          G1 E-10 F3600  ; retract 10mm of filament
          G91            ; relative positioning
          G1 Z5 F360     ; lift Z by 5mm
          G90            ; absolute positioning
          G1 X0 Y0 F6000 ; go to X=0 Y=0
          Stop.g
          ; stop.g
          ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled)
          ; generated by RepRapFirmware Configuration Tool v2.1.8 on Sun Feb 02 2020 20:26:37 GMT-0600 (Central Standard Time)
            Try creating a cancel.g with some sort of commands in it. Turn off heaters and rehome x and y or something like that.
            • projectR3D
              Ill give that a try, it only happens with S3D files and only on the duet3. The most common error is the upload and print then getting stuck in the loop, do you have any experience with that?
                I don't use S3D and haven;t heard of anything like that.
                How are you uploading the files from S3D? Curl script I assume? or from DWC?
                • projectR3D
                  Upload with DWC. It just happened again
                  m122
                  Static ram: 154604
                  Exception stack ram used: 516
                  Never used ram: 75132
                  Tasks: NETWORK(ready,1972) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1420) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,4928) IDLE(ready,76)
                  Owned mutexes:
                  Last reset 00:11:33 ago, cause: software
                  Last software reset at 2020-09-15 05:17, reason: Memory protection fault, spinning module Move, available RAM 75040 bytes (slot 0)
                  Software reset code 0x4164 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x0444a804 BFAR 0xe4aa804a SP 0x20417ba4 Task MAIN
                  Stack: 004256fd 00423352 010f0000 00000000 ffffffff 00000000 00000000 00000000 00000000 2042d338 00463e7b
                  Error status: 0
                  MCU temperature: min 51.5, current 51.8, max 52.9
                  Supply voltage: min 23.8, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                  12V rail voltage: min 12.3, current 12.3, max 12.4, under voltage events: 0
                  Driver 0: standstill, reads 41247, writes 19 timeouts 0, SG min/max 0/181
                  Driver 1: standstill, reads 41248, writes 19 timeouts 0, SG min/max 0/181
                  Driver 2: standstill, reads 41248, writes 19 timeouts 0, SG min/max 0/145
                  Driver 3: standstill, reads 41249, writes 19 timeouts 0, SG min/max 0/147
                  Driver 4: standstill, reads 41249, writes 19 timeouts 0, SG min/max 0/140
                  Driver 5: standstill, reads 41255, writes 14 timeouts 0, SG min/max 0/0
                  Date/time: 2020-09-15 05:28:41
                  Slowest loop: 5.52ms; fastest: 0.15ms
                  === Storage ===
                  Hiccups: 0(0), FreeDm: 375, MinFreeDm: 373, MaxWait: 620834ms
                  === MainDDARing ===
                  === AuxDDARing ===
                  Segments left: 0
                  File* is idle in state(s) 0
                  Daemon* is idle in state(s) 0 0, running macro
                  === Network ===
                  Slowest loop: 0.98ms; fastest: 0.01ms
                  - Ethernet -
                  State: disabled
                  === CAN ===
                  Messages sent 2778, longest wait 0ms for type 0
                  Last transfer: 20ms ago
                  RX/TX seq numbers: 36345/22606
                  Buffer RX/TX: 0/0-0
                  Daemon:
                  Finishing macro daemon.g, started by system
                  > Next stack level
                  Full transfers per second: 32.53
                    Phaedrux Moderator @projectR3D last edited by
                    @projectR3D said in Duet3 Stuck in spin loop:
                    Thanks.
                    You may also be able to get more information by enabling debugging.
                    https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Monitoring_optional
                    projectR3D 1 Reply Last reply Reply Quote 0
                    • projectR3D
                      projectR3D @Phaedrux last edited by
                      @Phaedrux Debugging has now been setup, would I see the additional info in M122 response?
                      • projectR3D
                        Response from debug
                        pi@duet3:~ $ sudo /opt/dsf/bin/DuetControlServer -1 debug
                        Written by Christian Hammacher for Duet3D
                        Licensed under the terms of the GNU Public License Version 3
                        [info] Settings loaded
                        [info] Environment initialized
                        [info] Connection to Duet established
                        [info] IPC socket created at /var/run/dsf/dcs.sock
                        Response from sudo /opt/dsf/bin/DuetWebServer
                        pi@duet3:~ $ sudo /opt/dsf/bin/DuetWebServer
                        info: Microsoft.Hosting.Lifetime[0]
                              Now listening on: http://[::]:80
                              Application started. Press Ctrl+C to shut down.
                              Hosting environment: Production
                              Content root path: /home/pi
                        info: DuetWebServer.Services.ModelObserver[0]
                              Connections to DuetControlServer established
                        info: Microsoft.AspNetCore.Hosting.Diagnostics[1]
                              Request starting HTTP/1.1 GET http://192.168.1.123/machine
                        info: Microsoft.AspNetCore.Routing.EndpointMiddleware[0]
                              Executing endpoint 'DuetWebServer.Controllers.WebSocketController.Get (DuetWebServer)'
                        info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[3]
                              Route matched with {action = "Get", controller = "WebSocket"}. Executing controller action with signature System.Threading.Tasks.Task Get() on controller DuetWebServer.Controllers.WebSocketController (DuetWebServer).
                        info: DuetWebServer.Controllers.WebSocketController[0]
                              WebSocket connected from ::ffff:192.168.1.114:59415
                              Request starting HTTP/1.1 GET http://192.168.1.123/machine/directory/0:%2Fmacros application/json
                              Executing endpoint 'DuetWebServer.Controllers.MachineController.GetFileList (DuetWebServer)'
                              Route matched with {action = "GetFileList", controller = "Machine"}. Executing controller action with signature System.Threading.Tasks.Task`1[Microsoft.AspNetCore.Mvc.IActionResult] GetFileList(System.String) on controller DuetWebServer.Controllers.MachineController (DuetWebServer).
                        info: Microsoft.AspNetCore.Mvc.Infrastructure.ContentResultExecutor[1]
                              Executing ContentResult with HTTP Response ContentType of application/json
                        info: Microsoft.AspNetCore.Mvc.Infrastructure.ControllerActionInvoker[2]
                              Executed action DuetWebServer.Controllers.MachineController.GetFileList (DuetWebServer) in 195.8381ms
                        info: Microsoft.AspNetCore.Routing.EndpointMiddleware[1]
                              Executed endpoint 'DuetWebServer.Controllers.MachineController.GetFileList (DuetWebServer)'
                        info: Microsoft.AspNetCore.Hosting.Diagnostics[2]
                              Request finished in 300.9561ms 200 application/json
