1.19beta7 and WiFi connect
while trying beta7 i encountered a problem during WiFi authentication.
i'm using "@" within my WPA-PSK. while using 1.18.2 this was possible, it isn't with beta7.
i read in some other thread that there are some possible issues with some characters.
will there be a fix, or should i think about changed my infrastructure?BR
I am surprised that 1.18 allowed password characters that 1.19 doesn't, I expected it to be the other way around. Are you sure it is the '@' character that is causing the problem?
hmmm… You're right. Tried the connection in several constellations. Result is that beta7/8 is able to use "@" because i was able to connect to the same SSID/WPA hosted by a different AP.
But within my trials i wasn't able to connect to my primary AP at all. Tried several reboots of the AP, different SSIDs/WPA combos without any success. I read that some users got issues with an AVM Fritzbox which i'm using too, but i don't know if it is related to that or if it is something ESP special.
When i remember correctly there was an ESP8266 WiFi issue where it didn't forget the config although the SDK command was used (the storage sector has to be deleted manually with flashEraseSector(0x3fe)). What i want to try is to completly reset the ESP and try to connect to an (at this point) unknown/new SSID.
BTW After downgrading to 1.18.2 WiFi connection to the same SSID/WPA works instantaneous without any problems! From my point of view it has something to do with a different way of interpretation of some stored parameters.
@dc42: is the ESP configured for non persistent SSID/WPA usage, so they aren't stored on ESP itself but only on SAM?
is there a possibility to reset/clear the ESP WiFi config (see above) via RRF? or only via direct ESP_COMMS?
One potential problem I have just realised concerns accented characters (although they didn't generally work on the older firmware anyway). On the older firmware, when you enter your SSID and password, accented characters will be sent over the web in UTF8 encoding. With the newer firmware, the encoding will depend on settings of the text editor that you use to create the macro file containing the M587 command.
To make matters worse, there are two different ways of representing most accented characters: either as a single combined character, or as a plain character followed by a combining accent.
Regarding the way we use the ESP8266, we always send it the SSID and password we want to connect to before we ask it to connect. The AP list is stored in flash on the ESP8266, but this is not the same flash area used by the SDK. However, I can see a few options that we can change to prevent the SDK functions storing connection details in its own flash area, and I will activate those in the next build. Also, when a connection fails I'll try to pass back the reason for the failure, e.g. authentication failed.
- after fiddling around a little bit more i think that the reason isn't located within the SSID/WPA-PSK combo. why? see below
- i think it has something to do with the "mode change" of the ESPs WiFi, as i get an connection to my WiFi once in a time after several calls of M552 S-1/0/1/2 (switching between AP, Client mode, Off)
- is it possible that the P parameter of the M552 is mandatory at the moment (use 0.0.0.0 if using DHCP) and didn't have an fallback value if none is defined?
[[language]] Connecting... Printer is now online. >>> M122 SENDING:M122 === Diagnostics === Used output buffers: 1 of 32 (1 max) === Platform === RepRapFirmware for Duet WiFi version 1.19beta8 running on Duet WiFi 1.0 Board ID: xxx Static ram used: 20900 Dynamic ram used: 96284 Recycled dynamic ram: 1600 Stack ram used: 3960 current, 4864 maximum Never used ram: 7424 Last reset 00:00:15 ago, cause: reset button or watchdog Last software reset reason: User, spinning module GCodes, available RAM 7568 bytes (slot 4) Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff Error status: 0 [ERROR] Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 0.0ms MCU temperature: min -207.9, current 48.9, max 49.1 Supply voltage: min 23.9, current 24.0, max 24.2, under voltage events: 0, over voltage events: 0 Driver 0: stalled standstill Driver 1: stalled standstill Driver 2: stalled standstill Driver 3: standstill Driver 4: standstill Date/time: 1970-01-01 00:00:00 Slowest main loop (seconds): 0.001749; fastest: 0.000031 === Move === MaxReps: 0, StepErrors: 0, MaxWait: 0ms, Underruns: 0, 0 Scheduled moves: 0, completed moves: 0 Bed compensation in use: none Bed probe heights: 0.000 0.000 0.000 0.000 0.000 Probe change coordinates: === Heat === Bed heater = 0, chamber heater = -1 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is ready with "M122" in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 Code queue is empty. Network state is changing mode WiFi module is trying to connect WiFi firmware version 1.19beta7 WiFi MAC address aa:bb:cc:dd:ee:ff WiFi Vcc 3.10, reset reason Turned on by main processor WiFi flash size 4194304, free heap 40728 HTTP sessions: 0 of 8 Socket states: 0 0 0 0 0 0 0 0 Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) >>> M587 SENDING:M587 Remembered networks: xxxx yyyy z.z WiFi reported error: failed to connect to access point Wifi module is idle >>> M552 SENDING:M552 WiFi module is idle >>> M552 S-1 SENDING:M552 S-1 WiFi module stopped >>> M552 S2 SENDING:M552 S2 WiFi module started WiFi reported error: Failed to start access point Wifi module is idle >>> M552 P0.0.0.0 S1 SENDING:M552 P0.0.0.0 S1 Wifi module is connected to access point xxxx yyyy z.z, IP address 192.168.0.247 ----- Network state is running WiFi module is connected to access point WiFi firmware version 1.19beta7 WiFi MAC address aa:bb:cc:dd:ee:ff WiFi Vcc 3.10, reset reason Turned on by main processor WiFi flash size 4194304, free heap 39736 WiFi IP address 192.168.0.247 WiFi signal strength -66db HTTP sessions: 1 of 8
I've just released DuetWiFiServer 1.18beta8. Please try it in case it helps. It disables persistence and auto-connect at startup. At the very least, it should provide a more detailed error message (to PanelDue and USB) if it fails to connect when you send M552 S1.
The P parameter of M552 isn't used on the Duet WiFi.
just uploaded WiFiServer beta8 and everything works as expected.
only get an error once while trying connect/disconnect/change mode now for 30+ times.
the error was:[[language]] WiFi reported error: Unexpected WiFi state 'idle' while trying to connect to
unfortunately i hurried to much, and i resettet the Duet, so i can't say if the above error is "self-healing" or not (retry after a timeout or something like this).
but it didn't occur a second time@dc42: thx!
upps… did it again...
after some hours online a reboot was needed, and afterwards no WiFi connection was establised.[[language]] >>> M552 SENDING:M552 WiFi module is idle >>> M552 S1 SENDING:M552 S1 WiFi reported error: Unexpected WiFi state 'idle' while trying to connect to Wifi module is idle
And no, it isn't an error of me that the "currentSsid" which should come after "… connect to ..." is missing.
So i think the config couldn't be read although M587 did list the known SSIDs[[language]] >>> M587 SENDING:M587 Remembered networks: xxxx yyyy z.z
Thanks, that gives me something to go on. If you try sending M552 S1 a few more times, does it connect eventually? If not, try M552 S-1 followed by M552 S1.
nope… this time no changes...
[[language]] >>> M552 S1 SENDING:M552 S1 WiFi reported error: Unexpected WiFi state 'idle' while trying to connect to Wifi module is idle >>> M552 S1 SENDING:M552 S1 WiFi reported error: Unexpected WiFi state 'idle' while trying to connect to Wifi module is idle >>> M552 S1 SENDING:M552 S1 WiFi reported error: Unexpected WiFi state 'idle' while trying to connect to Wifi module is idle >>> M552 S1 SENDING:M552 S1 WiFi reported error: Unexpected WiFi state 'idle' while trying to connect to Wifi module is idle >>> M552 S1 SENDING:M552 S1 WiFi reported error: Unexpected WiFi state 'idle' while trying to connect to Wifi module is idle >>> M552 S1 SENDING:M552 S1 WiFi reported error: Unexpected WiFi state 'idle' while trying to connect to Wifi module is idle >>> M552 S1 SENDING:M552 S1 WiFi reported error: Unexpected WiFi state 'idle' while trying to connect to Wifi module is idle >>> M552 S-1 SENDING:M552 S-1 WiFi module stopped >>> M552 S1 SENDING:M552 S1 WiFi module started WiFi reported error: Unexpected WiFi state 'idle' while trying to connect to Wifi module is idle >>> M552 S1 SENDING:M552 S1 WiFi reported error: Unexpected WiFi state 'idle' while trying to connect to Wifi module is idle >>> M552 S1 SENDING:M552 S1 WiFi reported error: Unexpected WiFi state 'idle' while trying to connect to Wifi module is idle >>> M552 S-1 SENDING:M552 S-1 WiFi module stopped >>> M552 S1 SENDING:M552 S1 WiFi module started WiFi reported error: Unexpected WiFi state 'idle' while trying to connect to Wifi module is idle
15-30 seconds between each try.
ok tested a little bit more… there seems to be a bug with EEPROM put/get.
szenario: all known SSIDs are deleted with M588 S"" and all AP configurations are deleted also with M589 S"".
[[language]] M588 S"*" ok M589 S"*" ok M587 No remembered networks ok
after that i established an AP config which is listed correctly with M587
[[language]] M589 S"duet" P"duet" I192.168.1.1 ok M587 Remembered networks: duet ok
when i try to start AP mode -> error, but AP config seems to be still stored
[[language]] M552 S2 ok WiFi reported error: Failed to start access point Wifi module is idle M587 Remembered networks: duet ok
add an client config and list again known configs the AP config is gone
[[language]] M587 S"test" P"test" ok M587 Remembered networks: test
M587 should not list the AP name as a remembered network if you are using beta 8 of DuetWiFiFirmware. Please check which version you are running. Tomorrow I'll check for coding errors in that area.
WifiServer beta8 and RRF beta8. see below:
[[language]] M122 === Diagnostics === Used output buffers: 1 of 32 (1 max) === Platform === RepRapFirmware for Duet WiFi version 1.19beta8 running on Duet WiFi 1.0 Board ID: xxxx Static ram used: 20900 Dynamic ram used: 96084 Recycled dynamic ram: 1800 Stack ram used: 3960 current, 4784 maximum Never used ram: 7504 Last reset 00:00:47 ago, cause: power up Last software reset reason: User, spinning module GCodes, available RAM 7180 bytes (slot 2) Software reset code 0x0003, HFSR 0x00000000, CFSR 0x00000000, ICSR 0x00400000, BFAR 0xe000ed38, SP 0xffffffff Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 0.0ms MCU temperature: min -210.4, current 41.4, max 41.5 Supply voltage: min 0.1, current 0.5, max 0.8, under voltage events: 0, over voltage events: 0 Driver 0: ok Driver 1: ok Driver 2: ok Driver 3: ok Driver 4: ok Date/time: 1970-01-01 00:00:00 Slowest main loop (seconds): 0.001695; fastest: 0.000027 === Move === MaxReps: 0, StepErrors: 0, MaxWait: 0ms, Underruns: 0, 0 Scheduled moves: 0, completed moves: 0 Bed compensation in use: none Bed probe heights: 0.000 0.000 0.000 0.000 0.000 Probe change coordinates: === Heat === Bed heater = 0, chamber heater = -1 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is ready with "M122" in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 Code queue is empty. Network state is running WiFi module is idle WiFi firmware version 1.19beta8 WiFi MAC address aa:bb:cc:dd:ee:ff WiFi Vcc 3.10, reset reason Turned on by main processor WiFi flash size 4194304, free heap 41104 HTTP sessions: 0 of 8 Socket states: 0 0 0 0 0 0 0 0 Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) ok
OK, I found the bug, it's purely a reporting issue. If you have no remembered networks but you have specified an access point name, then when you list remembered networks it prints the access point name. After you have added a remembered network, you can still retrieve the own access point name by sending M589. The fix will be in the next beta.
I still haven't worked out why it's trying to connect to an empty SSID. I'll look at that later today.
@dc42: as per definition the passphrase within the AP mode hast to be at least 8 chars long, i think it would be reasonable to check for valid M589 input (i think ssid min 0 max 32 chars and passphrase min 8-64 chars).
try:[[language]] M552 S0 ok WiFi module started M589 S"test" P"test" I192.168.1.1 ok M552 S2 ok WiFi module started WiFi reported error: Failed to start access point Wifi module is idle M589 S"test" P"testtest" I192.168.1.1 ok M552 S2 ok Wifi module is providing access point test, IP address 192.168.1.1
Thanks for the suggestion, I'll implement it in the next beta.
I can't reproduce the problem with failing to connect and not displaying the SSID name, but I've built a new DuetWiFiServer.bin with some changes that may help and put it at https://dl.dropboxusercontent.com/u/19369680/DuetWiFiServer.bin. Please try it.
will give it a try. will give feedback tomorrow.
is there the possibility to erase the ESP (incl. flash) completly from SAM/RRF? or only via ISP?
@dc: i think i found the reason, why an empty config was read…
SocketServer.cpp - row 64
[[language]] for (size_t i = 1; i <= MaxRememberedNetworks; ++i)
shouldn't it be```
[[language]]
for (size_t i = 0; i <= MaxRememberedNetworks; ++i)same in row 83 or better (i think) not to waste one slot at the beginning (row 64, 83, 112, 521,…)
[[language]]
for (size_t i = 0; i < MaxRememberedNetworks; i++)
The first entry is the configuration for the WiFi module as an access point. So the count starts from 1 when it is searching for a remembered SSID.
hmmm… once again:
[[language]] for (int8_t i = 0; i < num_ssids; ++i) { if ((strongestNetwork < 0 || WiFi.RSSI(i) > WiFi.RSSI(strongestNetwork)) && RetrieveSsidData(WiFi.SSID(i).c_str(), ssidData)) { strongestNetwork = i; } }
WiFi.RSSI's and WiFi.SSID's parameters are a zero based index from prior discovered SSIDs by blocking WiFi.scanNetworks(false, true)
At this point we are looking at the wrong index. aren't we? ++i -> i++
@dc: 1.19beta8+1 doesn't change the WiFi behaviour. but can you plz. confirm/check the above post?
Using ++i or i++ does exactly the same thing if the operand has primitive type and you don't use the value within the same expression, as in this case.
I just got a Duet Wifi and I'm having a hell of a time with the WIFI setup. I have tried flashing 1.18 stable as well as 1.19 beta 8. I first attempted upgrades via M997 but eventually tried the erase/reset/reload via samba. I have gotten it to connect once or twice but it seems whenever I edit config.g to uncomment M552 S1 it fails to connect again after reboot. I have fiddled with it quite a bit since then and haven't been able to get it to talk to my router again.
I've noticed a couple things
- when using 1.18 M552 will say that the board is in AP mode but I can't see it in my list of WIFI networks.
- when it does this it also says hostname is some bunch of gibberish ascii characters
- when using 1.19 Beta 8 M587 returns the two remembered networks I have configured in my SetNetwork macro however when I do a M552 S1 I get
M587
SENDING:M587
seawest
seawest 5GM552 S1
SENDING:M552 S1
WiFi reported error: no known networks found
Wifi module is idleI'm starting to think the board is faulty. Is there anything else I can try? It's almost as if the WIFI module is retaining some kind of garbage. Is there a way to purge everything so I'm starting fresh? SD Card, memory, everything?
The "no known networks found" message means that it did a network scan and didn't find either of the SSIDs you configured. How strong is the signal from your router where the Duet is? Is the Duet surrounded by metalwork that would attenuate the signal?
The Duet WiFi does 2.4GHz only, and I presume seawest 5G is a 5GHz access point.
I think access point names are case sensitive. Is 'seawest' exactly how your access point name appears when you connect to it from a smartphone, tablet etc. ?
wow thanks for the quick reply. seawest is the name of my 2.4 Ghz network and my seawest 5G is my 5 Ghz network. Both are off of the same ASUS router that sits about 10 feet away. The names are case sensitive and exactly as they're seen from my iphone. My password is alphanumeric and only contains letters and a number.
The thing that makes me suspicious that the board is bad is the fact that I don't see "Duet WIFI" when the board thinks it's in AP mode when using 1.18. Are there any debug commands I can use to test the functionality of the WIFI module itself? I was able to get the board to connect a handful of times and it seemed tied to loading a new WIFI firmware. However, I have tried reloading firmware several times since then and I haven't been able to re-establish a connection.
I WAS able to connect to the "Duet WIFI" SSID but only once. When that occurred I could see my neighbor's APs as well as my own. I was also able to get into the web interface but as soon as I uncommented "M552 S1" and rebooted I had the same problems all over again and could not reconnect.
