Endstop Question
  • I am new to the duet platform and reprap firmware. I am very comfortable with Marlin firmware. Here is what is going on. I recently purchased a duet 2 wifi and wired it to my Ender CR-10 v2 that was working with the stock ender controller. I also have a bltouch wired onto the printer.
    The duet had firmware 2.05.1 and I immediately upgraded it to firmware 3.0 then to 3.1.1. I then ran the web configurator tool to generate my zip file, which I uploaded to the board.
    I am just trying to get the basics working and I can't get the endstops working. I wired in the NC end stops and the led on the board is lit when the endstop isn't pressed and turns off when it is pressed.
    The issue is when I type the M119 command I am getting
    Endstops - X: no endstop, Y: no endstop, Z: no endstop, Z probe: not stopped
    Nothing I do makes a change and I am pulling my hair out.
    Here is my config.g file
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Sep 15 2020 09:37:17 GMT-0500 (Central Daylight Time)
    M550 P"Deere_CR10_v2" ; set printer name
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X300 Y300 Z400 S0 ; set axis maxima
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    G31 P500 X47 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
    M557 X15:285 Y15:285 S20 ; define mesh grid
    M106 P0 C"E_Fan" S1 H-1 ; set fan 0 name and value. Thermostatic control is turned off
    M950 F1 C"fan2" Q500 ; create fan 1 on pin fan2 and set its frequency
    M106 P1 C"E_Fan_PWM" S0 H1 T45 ; set fan 1 name and value. Thermostatic control is turned on
  • Moderator
    @kgrigio Send M115 to the Duet and post the reply. My guess is that the Duet hasn't actually updated to 3.1.1, because your endstop definition looks correct for RRF3, but won't work on RRF2.
  • M115
    FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
  • put M574 into the web ui console and post the output
  • @kgrigio said in Endstop Question:
    unrelated buy you have not configured your thermistor correctly
  • M574
    Endstop configuration:
    X: none
    Y: none
    Z: none
  • @kgrigio
    this indicates that your config was not read.
    is the config you posted from your lokal computer or from the duet located in the sys folder ?
  • What is on the duet, at least I think. I uploaded the system files from my configuration zip file. Do I need to do anything once I upload them to make them "take"
  • please go to the web ui
    file managment -> system.
    and click on the config.g file and verifiy that they are identical
  • What I pasted above is from the file management -> systems -> config.g file, but I just figured it out. When I opened the file, I then hit save and it now works.
    This begs the question, when I upload a new configuration.zip file why wouldn't this automatically save and start being used? Do I need to go in and save every time I upload? Do I need to save all the files?
    you need to restart the duet to read the initial configuration. when editing the config.g after saving it will ask you to do so.
    so any config changes require a restart.
  • Perfect. Thanks for the help. Now on to fix the other items, like the endstops you pointed out.
  • @kgrigio
    has the output of M574 changed?
  • Yes, now I am reading as follows
    M574
    X: low end switch connected to pin xstop
    Y: low end switch connected to pin ystop
    Z: low end Z probe
    On the thermistors you mentioned above. What didn't I configure correctly? I haven't looked at this closely yet as I am going between this and helping my kids with virtual school today. Thanks again for the help.
  • @kgrigio
    B4138 is the default. that type of thermistor has not been used in years.
    you need to figure out which thermistor is used in your printer.
    creality tend to use epcop 100k thermistors.
    https://github.com/MarlinFirmware/Configurations/blob/import-2.0.x/config/examples/Creality/CR-10 V2/Configuration.h
    and marlin uses that as well.
    so try the values from this guide
    https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38
    but use R4700 for the duet wifi
  • Perfect. Thanks.
