Height map missing
Anyone else missing Height Map from machine control in web browser
but not missing on Pi screen ?Cheers
C
@Carlo it's now a plugin in 3.2.0 under general->plugins
OK guys, maybe you will tell me I'm not doing the right way but it took me some time to find the information...
Because I was searching here :
https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.mdBut at least I've found the correct changes notes here :
https://github.com/Duet3D/DuetWebControl/releasesQuestion: what are you doing such confusing things ? Every time I'm searching the documentation it's a pain ! too much documents with too much versions !!
I think I understood, I've upgraded the firmware (combined) and I checked the releases notes with it ... but at least the bin file upgraded the Web interface...and not the firmware by the way, when I checked I see "RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)" instead of the 3.2.0-b2
Thanks guys for the support
@toufou54 If this is all confusing I suggest you hold off on updating to a beta firmware release.
