    Constant stopping
    446
    • rickypilnikundefined
      rickypilnik
      I started having an issue recently quite out of the blue, not after any updates or anything where any file I started printing just keeps stopping. Basically it performs a few lines of gcode then stops - e.g the initial wipe maneuver takes place and then the printer stops and pauses for 30 seconds or so and then performs another few lines and pauses again. Any ideas what's going on? Here are the board specs:
      Board: Duet 2 WiFi (2WiFi)
      Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.1.1 (2020-05-19b2)
      Duet WiFi Server Version: 1.23
      • Vetiundefined
        Veti
        post the output of m122 and your config.g
          rickypilnik
          m122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
          Board ID: 08DGM-956GU-DJMSN-6JTD6-3SJ6L-9BNHF
          Used output buffers: 3 of 24 (10 max)
          Static ram: 27980
          Dynamic ram: 93892 of which 20 recycled
          Exception stack ram used: 544
          Never used ram: 8636
          Tasks: NETWORK(ready,384) HEAT(blocked,1168) MAIN(running,1824) IDLE(ready,80)
          Owned mutexes: WiFi(NETWORK)
          Last reset 00:00:30 ago, cause: power up
          Last software reset at 2020-09-06 17:31, reason: User, spinning module GCodes, available RAM 8356 bytes (slot 2)
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
          Error status: 0
          MCU temperature: min 22.8, current 27.4, max 27.7
          Supply voltage: min 13.5, current 13.6, max 13.7, under voltage events: 0, over voltage events: 0, power good: yes
          Driver 0: standstill, SG min/max 0/275
          Driver 1: standstill, SG min/max 4/320
          Driver 2: standstill, SG min/max 0/0
          Date/time: 2020-09-19 17:18:24
          Cache data hit count 48905813
          Slowest loop: 7.60ms; fastest: 0.12ms
          === Storage ===
          Free file entries: 10
          SD card longest read time 1.1ms, write time 0.0ms, max retries 0
          Hiccups: 0(0), FreeDm: 169, MinFreeDm: 167, MaxWait: 18366ms
          === MainDDARing ===
          Scheduled moves: 5, completed moves: 5, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
          === AuxDDARing ===
          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          Daemon is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Slowest loop: 156.25ms; fastest: 0.00ms
          Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is active
            WiFi firmware version 1.23
            WiFi MAC address 5c:cf:7f:76:6d:15
            WiFi Vcc 3.38, reset reason Unknown
            WiFi flash size 4194304, free heap 23000
            WiFi IP address 172.16.1.144
            WiFi signal strength -60dBm, reconnections 0, sleep mode modem
          config (3).g
            rickypilnik
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Sep 05 2020 17:18:00 GMT+0100 (British Summer Time)
            M550 P"Ricky's CR-10" ; set printer name
            M551 P"Cyborg123" ; set password
            M552 S1 ; enable network
            M586 P0 S1 ; enable HTTP
            M586 P1 S0 ; disable FTP
            M586 P2 S0 ; disable Telnet
            M569 P0 S0 ; physical drive 0 goes backwards
            M569 P3 S0 ; physical drive 3 goes backwards
            M350 E256 X256 Y256 Z256 I0 ; configure microstepping without interpolation
            M92 X1280.00 Y1280.00 Z6400.00 E1715.00 ; set steps per mm
            M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
            M203 X9000.00 Y9000.00 Z480.00 E1200.00 ; set maximum speeds (mm/min)
            M201 X575 Y575 Z100 E575 ; set accelerations (mm/s^2)
            M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X300 Y300 Z400 S0 ; set axis maxima
            M574 Z1 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop
            M558 P0 H1 F210 T9000 ; disable Z probe but set dive height, probe speed and travel speed
            M557 X15:230 Y15:285 S30 ; define mesh grid
            M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
            M950 F2 C"fan1" Q500 ; create fan 2 on pin fan1 and set its frequency
            M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
            M501
            • Vetiundefined
              Veti
              this is overloading your cpu.
              change to x16 with interpolation
              dont forget to change the steps/mm
                rickypilnik
                Thanks, I'll do that, set a print going and get back to you
                • Vetiundefined
                  Veti
                  on a side node your themistors are incorrect
                  M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedted
                  B4138 is the default and incorrect for your thermistors.
                  try the values from
                  https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38
                  creatlity uses the same on most of their printers.
                    rickypilnik
                    Having changed the motor and thermistor settings, run an auto-tune I started a print again. Unfortunately, the same thing keeps happening
                    Here is the updated config for convenience
                    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Sep 19 2020 17:38:32 GMT+0100 (British Summer Time)
                    M350 E256 I0 ; configure microstepping without interpolation
                    M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation
                    M92 X80.00 Y80.00 Z6400.00 E1715.00 ; set steps per mm
                    M203 X9000.00 Y9000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                    M201 X3000.00 Y3000.00 Z250.00 E5000.00 ; set accelerations (mm/s^2)
                    M906 X1125 Y1125 Z1125 E1125 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M308 S0 P"bedtemp" Y"thermistor" T98801 B4185 ; configure sensor 0 as thermistor on pin bedtemp
                    M143 H0 S80 ; set temperature limit for heater 0 to 80C
                    M308 S1 P"e0temp" Y"thermistor" T98801 B4185 ; configure sensor 1 as thermistor on pin e0temp
                    M501
                    Phaedruxundefined Vetiundefined 2 Replies Last reply Reply Quote 0
                    • Vetiundefined
                      Veti
                      can you post the m122 after this happens?
                      the first was just after a restart
                        Phaedrux Moderator @rickypilnik
                        @rickypilnik said in Constant stopping:
                        Do you have mesh compensation active during a print? Low Z jerk values can cause stuttering X Y movement.
                        • Vetiundefined
                          Veti @rickypilnik
                          you forgot to adjust the z steps
                            rickypilnik
                            Adjusted steps, checked compensation is on and the pauses are still happening. Its not so much a jerk as a complete stop, wait for a bit and then continue. Here is an m122 during a stop
                            m122
                            Used output buffers: 1 of 24 (21 max)
                            Static ram: 27980
                            Exception stack ram used: 504
                            Never used ram: 8676
                            Tasks: NETWORK(ready,368) HEAT(blocked,1224) MAIN(running,1840) IDLE(ready,80)
                            Owned mutexes:
                            Last reset 00:20:15 ago, cause: software
                            Last software reset at 2020-09-20 13:29, reason: User, spinning module GCodes, available RAM 8692 bytes (slot 2)
                            Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                            Error status: 0
                            MCU temperature: min 36.0, current 36.1, max 36.4
                            Supply voltage: min 13.2, current 13.5, max 13.7, under voltage events: 0, over voltage events: 0, power good: yes
                            Driver 3: ok, SG min/max not available
                            Date/time: 2020-09-20 13:49:29
                            Cache data hit count 2128334024
                            Slowest loop: 5.76ms; fastest: 0.12ms
                            === Storage ===
                            Free file entries: 9
                            SD card longest read time 1.0ms, write time 0.0ms, max retries 0
                            Hiccups: 0(0), FreeDm: 168, MinFreeDm: 165, MaxWait: 0ms
                            === MainDDARing ===
                            Scheduled moves: 489, completed moves: 484, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3
                            === AuxDDARing ===
                            Heater 0 is on, I-accum = 0.4
                            Heater 1 is on, I-accum = 0.5
                            Segments left: 1
                            File is doing "G0 X161.15 Y153.617" in state(s) 0
                            === Network ===
                            Slowest loop: 199.89ms; fastest: 0.09ms
                            • WiFi -
                              Failed messages: pending 0, notready 0, noresp 4
                              WiFi flash size 4194304, free heap 24584
                              WiFi signal strength -64dBm, reconnections 0, sleep mode modem
                              I suggest raising the Z jerk to M566 Z60 and trying again.
                              The low jerk values means that as the Z height changes with the heightmap the XY axis has to slow down to give time for the Z axis to move since it has to obey the lowest value.
                              Reducing the first layer speed can also help.
