Low voltage on Duet 2 Maestro FAN1 and FAN2 ports
Hello everyone,
I'm in the process of upgrading my Ender 3 Pro fans to 12V. I'm using Duet 2 Maestro with firmware 3.1.1 (2020-05-19b2).
I have a buck converter with inputs wired to VIN+ and VIN-. The converter is set up to output 12V and this is verified with multimeter.
I have wired the buck converter OUTPUT+ to both V_FAN_A (jumper middle pin) and V_FAN_B (jumper middle pin). (Same problem existed when I had it only wired to V_FAN_A)
When I power up the machine and start checking the fan ports with multimeter I get the following results:
Always-on-fan 12V (correctly).
FAN0, FAN1 and FAN2 0V (correctly).After this I heat the hot end to 55 C (fan temperature threshold at 45 C), set the part cooling fan to 100% from DWC and check the ports with multimeter again:
FAN0 12V (correctly)
FAN1 7V
FAN2 7VSo something is wrong with FAN1 and FAN2 voltage and I can't figure out what it is. Can anyone help?
Can you post your fan configuration section?
@Phaedrux Sure
; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S0 H1 T45 ; set fan 1 value. Thermostatic control is turned on M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency M106 P2 S0 H1:0 T45 ; set fan 2 value. Thermostatic control is turned on
The reason is the S0 parameters in the M106 commands for your thermostatic fans. When a fan is configured in thermostatic mode, the S parameter is the maximum allowed PWM (to handle fans that are too powerful when run at full PWM). However, RRF forces a minimum PWM of 50% for thermostatic fans.
So either remove the S parameters for those M106 commands, or change them to S1.
Thanks a lot! This fixed it.
