    connect problem..
    Duet Web Control
    • MRJEONundefined
      MRJEON
      When I type the IP address to access duet wifi web control, it does not come out. What is the problem?
      m122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
      Board ID: 08DLM-996RU-N85S4-7JTD8-3S46R-9VBVP
      Used output buffers: 5 of 24 (5 max)
      Static ram: 25712
      Dynamic ram: 93020 of which 0 recycled
      Exception stack ram used: 256
      Never used ram: 12084
      Tasks: NETWORK(ready,1304) HEAT(blocked,912) MAIN(running,3752) IDLE(ready,160)
      Owned mutexes:
      Last reset 00:00:39 ago, cause: software
      Last software reset time unknown, reason: Heat task stuck, spinning module GCodes, available RAM 11680 bytes (slot 2)
      Software reset code 0x00a3 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0043380f BFAR 0xe000ed38 SP 0x200049d4 Task 0x4e49414d
      Stack: 004486cf 0042a316 21000000 3f800000 00000000 00000000 00000000 3331bb4c 40000000 3f317200 b5ddea0e 388aa908 bb35fe81 00000000 00000000 00000000 3f800000 3f800000 3f800000 20000010 0042a2f1 000000c1 20007fd8
      Error status: 0
      Free file entries: 10
      MCU temperature: min 34.6, current 35.1, max 35.3
      Supply voltage: min 1.6, current 1.7, max 1.8, under voltage events: 0, over voltage events: 0, power good: no
      Driver 0: ok, SG min/max not available
      Driver 1: ok, SG min/max not available
      Driver 2: ok, SG min/max not available
      Driver 3: ok, SG min/max not available
      Driver 4: ok, SG min/max not available
      Cache data hit count 60467111
      Slowest loop: 99.59ms; fastest: 0.05ms
      Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
      === DDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
      Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is ready with "m122" in state(s) 0
      aux is idle in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 1.27ms; fastest: 0.00ms
      HTTP sessions: 0 of 8
      • WiFi -
        Network state is running
        WiFi module is idle
        WiFi firmware version 1.23
        WiFi MAC address ec:fa:bc:5b:45:b7
        WiFi Vcc 3.36, reset reason Turned on by main processor
        WiFi flash size 4194304, free heap 30176
        ok
        m122 p104
        Testing SD card write speed...
        SD write speed for 10.0Mbyte file was 2.59Mbytes/sec
        ok
        m22
        SD card 0 may now be removed
        ok
        m21
        SDHC card mounted in slot 0, capacity 7.95Gb
        ok
        m122 p104
        SD write speed for 10.0Mbyte file was 2.39Mbytes/sec
        ok
        m587
        Remembered networks:
        TNCAPF318D9 IP=192.168.1.24 GW=0.0.0.0 NM=0.0.0.0
        clane IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
        ok
        jay_s_uk
        What do you mean it does not come out?
        What error is displayed in your web browser?
        • MRJEONundefined
          MRJEON
          I cannot enter the web browser.
          • PCRundefined
            PCR
            @MRJEON which sofware have you used to enter the M587 command?
            have you done a M552 S1 after the M587?
              jay_s_uk
              if its an issue actually getting the web browser (i.e. chrome, firefox etc) working on your computer then we may be able to help you but thats beyond our remit.
              If its an issue trying to load duet web control (DWC - the duet web interface) then a little more information is needed.
              What error is being displayed? Does it say host unreachable? Is it timing out? Does it say the connection is rejected? Does it say the www files aren't present on the SD card?
              Please give us more information or even a screenshot of what you see, otherwise we can only speculate to the issue.
                Phaedrux Moderator @MRJEON
                @MRJEON said in connect problem..:
                How did you get the IP address?
                Can you ping that IP address?
