    Mesh compensation no longer working in RRF3
    • gamer_013
      gamer_013 last edited by gamer_013
      I use an inductive sensor wired to the e0stop and I used to be able to do mesh compensation and use the bed leveling assistant but now it's giving me the error G30: Z probe 0 not found. It looks like G29/30 can only use probe 0 which look like it should be setup by default from the wiki on M558. Is my "Z probe connected to E0 endstop input" not a z probe? Or how should I perform G29/G32 operations now?
      ; config.g
      ; Define Position of Bed Leveling Screws
      M671 X11:296:153 Y0:0:280
      M574 X1 S1 P"xstop"
      M574 Y1 S1 P"ystop"
      M574 Z1 S1 P"!e0stop"
      ;X & Y are active high
      ;Z is inverted, see M558 below
      ; Set Z probe type
      M558 P5 C"!e0stop" H3 F120 T18000
      G31 X5 Y-47 Z0.5	; Set Z probe trigger value, offset and trigger height. Higher value brings nozzle closer to bed
      			; (this G31 line must come *after* M558 line)
      ; bed.g
      ; called to perform automatic bed compensation via G32/29
      M913 Z70			; Reduce Z motor current so if the Z sensor fails
      				; and there's a head crash there's less force
      M561				; Clear any existing bed transform
      G29 S2				; Clear previous height map
      G28 ; home
      G30 P0 X11  Y0   Z-99999 ; probe near an adjusting screw
      G30 P1 X296 Y0   Z-99999 ; probe near an adjusting screw
      G30 P2 X153 Y253 Z-99999 S3 ; probe near an adjusting screw and report adjustments needed
      M913 Z100			; Restore Z motor current currents
      fcwilt 1 Reply Last reply Reply Quote 0
      • jay_s_uk
        jay_s_uk last edited by
        Your issue if you're trying to set the same pin as a z endstop and a z probe.
        Just remove the M574 for Z
        Owns various duet boards and is the main wiki maintainer for the Teamgloomy LPC/STM32F4 port of RRF
        gamer_013 1 Reply Last reply Reply Quote 0
        • Veti
          Veti last edited by
          @gamer_013 said in Mesh compensation no longer working in RRF3:
          replace with
          M574 Z1 S2 ; configure Z-probe endstop for low end on Z
          • fcwilt
            fcwilt @gamer_013 last edited by fcwilt
            @gamer_013
            JOOC why are you not using the Z-probe connector?
            Printers: A FT-5 with the 713 upgrade bits. A custom MarkForged style. A small Utilmaker style and a CoreXY from kits. Various hotends. Using Duets (2 and 3) running 3.4.0
            • gamer_013
              gamer_013 @jay_s_uk last edited by
              @jay_s_uk said in Mesh compensation no longer working in RRF3:
              Removing this line gives me a "failed to enable endstops" error when trying to home Z.
              @Veti said in Mesh compensation no longer working in RRF3:
              replace with
              That did it! I didn't think so try that as the gcode wiki said "The S2 option of M574 is intended for use only when axes other than Z are using the Z probe for homing." Which confused me because I was using my "z probe" to home the z axis so I didn't consider the S2 option. Thank you!
              @fcwilt said in Mesh compensation no longer working in RRF3:
              @gamer_013
              This is carried over from an old config that I used long ago and the example happened to have it setup that way. I may convert it over when I get some time to re-configure my printer.
