    SOLVED Duet2 wifi setting bl touch z offset help.
    100
    • Anvil
      Anvil last edited by
      So im running into an issue with the z offset on my ender 5 plus with bltouch. I got it printing beautifully and my only issue was a slightly too high first layer. (Getting gaps in my base layer) so i figured i just need to lower my z offset just a little. Im new to abl so i had to look up some guides on how to do it. So essentially im setting the z offset in the config to zero.. going to mid bed about 10mm z height. Sending g30... jogging down to a .1 feeler gauge... m92 z.1. Raising 10mm again ans sending g30 s-1... (its displayed around 2.15 every time)... gone into my config and changed the z offset to what my readout was.... and when i save and restart... after re-homing im always about 7.5mm off the print bed and z reads at 2.5mm. Ive even tried changing the offset to something crazy like 4.5 and it doest change.... im almost really wishing i just left the first layer as is... is there something im missing? Do i need to modif another one of my sys files to get the changes to stick? Do i need to make all the changes in the console instead of modifying the config file and saving?
      • Veti
        Veti last edited by
        post your config.g
        • Anvil
          0:/sys/config.g
          ; generated by RepRapFirmware Configuration Tool v2.0.3 on Fri Sep 13 2019 00:35:32 GMT+0100 (British Summer Time)
          M550 P"Ender 5 Plus" ; set printer name
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S1 ; enable FTP
          M586 P2 S1 ; enable Telnet
          M569 P3 S0 ; physical drive 3 goes backwards
          M92 X80.40 Y80.00 Z796.01 E274.64 ; set steps per mm
          M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
          M906 X800 Y800 Z800 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X-5.5 Y0 Z0 S1 ; set axis minima
          M208 X350 Y350 Z400 S0 ; set axis maxima
          M574 X1 Y1 S1 ; set active high endstops
          M574 Z1 S2 ; set endstops controlled by probe
          M307 H3 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
          M558 P9 H2.5 F180 T6000 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X45 Y-3 Z2.14 ; set Z probe trigger value, offset and trigger height
          M557 X0:305 Y0:315 S25 ; define mesh grid
          M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
          M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
          M106 P0 S1 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
          M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
          ; Custom settings
          M591 D0 P2 C3 S1 ; Filament Run out sensor
          G29 S1 ; Load mesh bed
          Ender 5 Plus
          Send code...
          Status
          Idle
          Tool Position
          X
          15.0
          Y
          15.0
          Z
          2.50
          Extruder Drives
          Drive 0
          0.0
          Speeds
          Requested Speed
          0 mm/s
          Top Speed
          0 mm/s
          Sensors
          Vin
          24.1 V
          MCU Temperature
          30.8 C
          Fan RPM
          0
          Z-Probe
          0
          Tools
          Extra
          Control All
          Tool Heater Current Active Standby
          Tool 0
          T0 - Load Filament Heater 1
          off 25.1 C
          0
          0
          Bed Heater 0
          off 25.0 C
          0
          0
          Temperature Chart
          System Directory
          • fcwilt
            fcwilt last edited by
            Well if it was too high then you needed to increase the probe Z trigger height setting.
            I don't put my probe settings in config.g since I would then have to reboot the printer to use the new values.
            I have a system file I created called configprobe.g which I can edit or run as needed. So in any place I need to be sure that probe is configured with the most current values I simply add the command M98 P"configprobe.g"
            Printers: A FT-5 with the 713 upgrade bits. A custom MarkForged style. A small Utilmaker style and a CoreXY from kits. Various hotends. All with a variety of Duets (2 and 3) running 3.3.0
            • Veti
              Veti last edited by
              @Anvil said in Duet2 wifi setting bl touch z offset help.:
              post your config overwrite
              unrelated but your thermistor settings are look.
              hmm its unlikely that your leadscrew is really that values. when you measured it it was most likely backlash that your measured.
              Anvil 1 Reply Last reply Reply Quote 0
              • Anvil
                Anvil @Veti last edited by
                @Veti
                Ill post the overwrite config when i get back from lunch.
                But what did you mean to say about my thermistors? They look.... ?
                And im not sure what you mean about measuring the backlash on the leadscrew?
                Everything was printing perfectly before i tried to adjust the z offset. Temps were consistent and those are the step values after adjusting for a calibration cube. So it was printing spot on dimensions. Just had gaps in my first layer.
                • Veti
                  Veti last edited by Veti
                  how did you arrive at your z steps?
                  for some info what backlash is. https://en.wikipedia.org/wiki/Backlash_(engineering)
                  every type of thermistor has a specific beta value.
                  this determines the resistance at a specific temperature.
                  if you are using the wrong value it might display 200C but the read temperature can easily be 20C off.
                  • Veti
                    Veti last edited by
                    most likely creality uses the same thermistors as the ender 3. see
                    https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+2:+Configuration/38
                    • Anvil
                      I know what backlash is, im a machinist. Im just not sure what you mean by how it applies to measuring my z steps. I copied a friends config file and checked it against another persons ender 5 plus steps... both stock values were 80, 80, and 800... then mine is minus some for the calibration adjustment to land on 20mm height of a calibration cube. Like i said... other than the first layer... it was printing perfectly before i attempted to change the z offset.
                      ah... well for the thermistors... The whole sys config I got from a friends sys config files for a baseline. Ive copied his printer exactly (which is tuned and printing great). and just been tweaking to get mine dialed...but i mean when the bed and hotend are at idle it reads the exact room temperature in my house.... I'm not sure if that makes any difference but... again everything was printing perfectly... im even using the same temps for filaments that i use on my other printer and if anything im noticing better performance... but i have no idea about thermistor beta values so i dont really know.
                      anywho... here's my overwrite config.
                      M503
                      ; Custom settings
                      • Anvil
                        @Veti
                        but either way... you seem very knowledgeable about this sort of thing Whats the normal procedure for adjusting the z offset so i can tweak my first layer? do you have a link to any good guide? Thanks for all the replies and insight.
                          https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+4:+Calibration/40
                          https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
                          Once The probe and extruder are calibrated and the bed level, you can print a large first layer and adjust the z height with baby stepping to get it just right, then use that amount and modify the G31 Z offset by that amount. If it doesn't stay consistent then it's either the probe that is inconsistent or the bed/z axis isn't stable.
                          • Anvil
                            Anvil @Phaedrux last edited by
                            @Phaedrux Thanks so much man. Just reloaded my backup stock sys files and then plugged in my steps and used the info you sent. running like a champ now!
                            • Veti
                              Veti last edited by
                              thats your config overwrite?
