    Error: over-temperature and Warning: VIN under-voltage
    • FBGundefined
      FBG
      Hello, this problem happen me usually in all printings...
      Always is the same:
      28/9/2020 13:36:49: : File 0:/gcodes/CFFFP.gcode selected for printing
      28/9/2020 13:39:54: : 63 points probed, min error -1.712, max error 0.044, mean -0.564, deviation 0.421
      Height map saved to file 0:/sys/heightmap.csv
      28/9/2020 22:55:50: : Cancelled printing file 0:/gcodes/CFFFP_0 PArte 2 DEF corte de la parada.gcode, print time was 9h 19m
      Error: over temperature shutdown reported by driver(s) 0 1 2 3 4
      Warning: VIN under-voltage event (6.5V)
      28/9/2020 22:55:52: : Error: G0/G1: insufficient axes homed
      And the M122 say:
      29/9/2020 8:44:14: M122: === Diagnostics ===
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet Ethernet 1.02 or later
      Board ID: 08DGM-917DA-G4MSD-6JTD6-3SN6R-9TT39
      Used output buffers: 1 of 24 (23 max)
      Static ram: 27980
      Dynamic ram: 93696 of which 20 recycled
      Exception stack ram used: 552
      Never used ram: 8824
      Tasks: NETWORK(ready,268) HEAT(blocked,1224) MAIN(running,1824) IDLE(ready,80)
      Owned mutexes:
      Last reset 21:55:31 ago, cause: power up
      Last software reset at 2020-09-04 13:01, reason: User, spinning module GCodes, available RAM 8904 bytes (slot 1)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
      Error status: 8
      MCU temperature: min 24.5, current 30.0, max 45.6
      Supply voltage: min 3.8, current 24.2, max 24.4, under voltage events: 2, over voltage events: 0, power good: yes
      Driver 3: standstill, SG min/max 0/202
      Driver 4: standstill, SG min/max 0/1023
      Date/time: 2020-09-29 08:41:56
      Slowest loop: 368.26ms; fastest: 0.10ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 9.2ms, write time 33.2ms, max retries 0
      Hiccups: 203509(0), FreeDm: 169, MinFreeDm: 111, MaxWait: 7347969ms
      Bed compensation in use: mesh, comp offset 0.004
      === MainDDARing ===
      Scheduled moves: 436593, completed moves: 436593, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      === AuxDDARing ===
      Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 367.27ms; fastest: 0.02ms
      HTTP sessions: 1 of 8
      Interface state active, link 100Mbps full duplex
      === Filament sensors ===
      Extruder 1 sensor: ok
      Like i said before, this not only happen me 1 time. Happen me 4-5 times, what is your opinion?
      Best regards
      • Vetiundefined
        Veti
        does your psu have a poweroff feature that you are using?
        if not your power supply might be failing
        • FBGundefined
          FBG
          Not use PSU, always is on...
            Phaedrux Moderator @FBG
            @FBG said in Error: over-temperature and Warning: VIN under-voltage:
            Check that the screw down terminals for VIN are tight. Make sure you are using the crimped bootlace ferrules.
            • FBGundefined
              FBG
              After test a lot time i can say that with "crimped bootlace ferrules" everything is ok.
              Thanks a lot!
