    Wiring duet3 6HC + tool distribution board + 2xToolboard 1LC
    • kroybalundefined
      kroybal
      According to documentation, there are some modifications to the cables required to make this setup work. From my understanding, I can just run the standard RJ11 from duet3 to the tool distribution board. However, from the distribution board to the toolboard are there some twisted pairs I will need to make up myself?
        dc42 administrators @kroybal
        That's correct.
        kroybalundefined 1 Reply Last reply Reply Quote 0
        • kroybalundefined
          kroybal @dc42
          @dc42 Thank you for your response.
          I have the RJ11 going from the Duet3, to the tool distribution board, I have jumpers across the can-out and on the unused tool ports.
          For setting up my twisted pairs is it pin-to-pin?
          meaning:
          a twisted pair for pins 1&2 go to pins 1&2 from distribution board to toolboard? etc.
          • T3P3Tonyundefined
            T3P3Tony administrators
            Yes they are straight from the tool distribution board to the toolboards
            www.duet3d.com
