    SKR 1.4 Turbo SBC Setup
    LPC
    • mrenz999undefined
      mrenz999
      I can't seem to get the printer to show connection to the SBC. I can pull up DWC, but it does not show any endstops, heaters, tools, or axis's.
      board.txt
      //Note: Each line should be less than 120 characters.
      // : Unwanted options can be commented out or set to NoPin. Lines commented out will get default values
      // : for pins the default is NoPin.
      // : Values for Arrays need to be contained within { and }
      // : Comments can be defined with // or # (comments are not supported inside arrays)
      // : Each config entry must be all on a single line.
      lpc.board = biquskr_1.4;
      //LED blinks to indicate Platform is spinning or other diagnostic
      //Comment out or set to NoPin if not wanted.
      leds.diagnostic = NoPin;
      //Internal SDCard SPI Frequency.
      lpc.internalSDCard.spiFrequencyHz = 25000000;
      //Only supports 1 External SDCard
      //externalSDCard.csPin = 0.16;
      //externalSDCard.cardDetectPin = 1.31;
      //lpc.externalSDCard.spiFrequencyHz = 4000000;
      //lpc.externalSDCard.spiChannel = 0;
      //LCD Pins (only ST9720 SPI currently supported)
      //setup the Software SPI Pins for LCD
      lpc.softwareSPI.pins = {1.20, NoPin, 1.18}; //Set to GPIO pins to use as SCK, MISO, MOSI
      lcd.spiChannel = 2;
      lcd.lcdCSPin = 1.19;
      lcd.lcdBeepPin = 1.30;
      lcd.encoderPinA = 3.26;
      lcd.encoderPinB = 3.25;
      lcd.encoderPinSw = 0.28; //click
      lcd.lcdDCPin = NoPin; //DataControl Pin (A0) if none used set to NoPin
      lcd.panelButtonPin = NoPin; //Extra button on RRD Panel
      heat.tempSensePins = {bedtemp, e1temp}; //Max of 3 entries
      //heat.spiTempSensorCSPins = { }; //Max of 2 entries
      //Analogue to Digital prefilter
      adc.prefilter.enable = true
      config.g
      Configuration file for SKR v1.4 (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.1.4-LPC-5 on Tue Sep 29 2020 20:24:48 GMT-0600 (Mountain Daylight Time)
      M550 P"Obokenpally's Mule" ; set printer name
      M918 P1 E4 F2000000 ; configure direct-connect display
      M552 S0 ; disable network
      M569 P0 S1 ; physical drive 0 goes forwards using default driver timings
      M569 P1 S1 ; physical drive 1 goes forwards using default driver timings
      M569 P2 S1 ; physical drive 2 goes forwards using default driver timings
      M569 P3 S1 ; physical drive 3 goes forwards using default driver timings
      M569 P4 S1 ; physical drive 4 goes forwards using default driver timings
      M584 X0 Y1 Z2 E3:4 ; set drive mapping
      M350 X16 Y16 Z16 E16:16 I1 ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E409.00:420.00 ; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
      M201 X700.00 Y700.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X310 Y320 Z400 S0 ; set axis maxima
      M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:310 Y15:320 S20 ; define mesh grid
      M950 H0 C"bed" T0 ; create bed heater output on bed and map it to sensor 0
      M308 S1 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e1temp
      M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
      M563 P1 S"Hemera" D1 H1 F0 ; define tool 1
      G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
        jay_s_uk
        I've messaged you on discord.
        mrenz999undefined 1 Reply Last reply Reply Quote 0
        • mrenz999undefined
          mrenz999 @jay_s_uk
          @jay_s_uk Ok thank you.
