    Z Offset variable while priting
    • duetloverundefined
      duetlover
      Hi everybody
      I need to change Z offset of a tool while printing for a specific application.
      At the moment, Z offset is set in config file :
      G10 P3 Z-35.50
      Is there a variable I can use to adjust Z offest with a line in gcode?
      Something like :
      G10 P3 Z*VarZOffset*+0.2
      and coming back to normal offset :
      G10 P3 Z*VarZOffset
      I'm running RFF3 firmware.
      Thanks !
        jay_s_uk
        Use babystepping rather than adjusting the z offset as thats only taken into account during probing moves
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M290_Baby_stepping
            duetlover
            Thank you, I will check this !
