    Bed levelling/traming odd message - 3.2 Beta 2
    Beta Firmware
    • jay_s_uk
      jay_s_uk last edited by
      I'm running 3.2 beta 2 on a mini5+ in SBC mode.
      I now get the following message
      Bed calibration : 2 factor calibration requested but only 0 points provided
      while running G32. I did not get this message in beta 1. This is the full output from the console showing that traming did take place.
      06/10/2020, 11:55:55	Bed Traming Cycle: 4 - Difference was 0.004mm
      06/10/2020, 11:55:55	Leadscrew adjustments made: -0.021 -0.038, points used 2, (mean, deviation) before (-0.029, 0.004) after (-0.000, 0.000)
      06/10/2020, 11:55:55	Bed Traming Cycle: 3 - Difference was 0.015mm
      06/10/2020, 11:55:55	Leadscrew adjustments made: -0.089 -0.020, points used 2, (mean, deviation) before (-0.058, 0.015) after (-0.000, 0.000)
      06/10/2020, 11:55:55	Bed Traming Cycle: 2 - Difference was 0.276mm
      06/10/2020, 11:55:55	Error: Bed calibration : 2 factor calibration requested but only 0 points provided
      06/10/2020, 11:55:54	Error: Bed calibration : 2 factor calibration requested but only 0 points provided
      06/10/2020, 11:55:54	Bed Traming Cycle: 1 - Difference was 0.276mm
      06/10/2020, 11:55:54	Leadscrew adjustments made: -0.720 0.553, points used 2, (mean, deviation) before (-0.131, 0.276) after (-0.000, 0.000)
      This is the contents of my bed.g
      M671 X-130:400 Y150:150 S10
      if !move.axes[0].homed || !move.axes[1].homed	; If the printer hasn't been homed, home it
      	G28 XY	; home y and x
      M98 P"0:/sys/homez.g"			; home z
      M561							; clear any bed transform
      ;M558 P9 H5 F120 T24000			; increase dive height
      M98 P"bed_twoscrews.g"		; perform bed tramming
      echo "Bed Traming Cycle: 1 - Difference was " ^ move.calibration.initial.deviation ^ "mm"
      while move.calibration.initial.deviation >= 0.01		; perform additional tramming if previous deviation was over 0.01mm
        if iterations = 5
          abort "Too many auto tramming attempts"
        echo "Bed Traming Cycle: " ^ iterations + 2 ^ " - Difference was " ^ move.calibration.initial.deviation ^ "mm"
        continue
      G28 Z							; home z
      and here is the bed_twoscrews.g
      G30 P0 X0 Y150 Z-99999         							; Probe near front left leadscrew
      G30 P1 X230 Y150 Z-99999 S2       							; Probe near front right leadscrew
      Any thoughts why?
      Owns various duet boards and is the main wiki maintainer for the Teamgloomy LPC/STM32F4 port of RRF
      • gloomyandy
        gloomyandy last edited by
        @dc42 @chrishamm I think this is the same problem I described in the email I sent you (but I've seen it on the LPC port). I get the same error messages due to dropped gcode lines/lines executed more than once.
        • chrishamm
          chrishamm administrators last edited by
          @gloomyandy I just replied to your mail. I'll need a debug log from DCS to figure out why this is happening. I haven't had this problem on my test platform yet.
          Duet software engineer
