BLTouch Zprobe marche pas
  • Bonjour depuis la MAJ vers 3.1 mon BLTouch se deploie plus je l'allume la pin se deploie correctement mais pour un G28 marche pas
  • ; Configuration file for Duet WiFi (firmware version 3)
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Oct 03 2020 15:26:33 GMT+0200 (heure d’été d’Europe centrale)
    M550 P"MonsterPrinter" ; set printer name
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P1 S0 ; physical drive 1 goes forwards
    M569 P5 S1 ; physical drive 5 goes forwards
    M569 P6 S1 ; physical drive 6 goes forwards
    M569 P7 S0 ; physical drive 7 goes forwards
    M584 X0:5 Y1:6 Z2:7 E3 ; set drive mapping
    M92 X100.00 Y80.00 Z400.00 E420.00 ; set steps per mm
    M566 X900.00 Y1400.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X9000.00 Y9000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X800 Y1950 Z1400 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M208 X-6 Y-10 Z0 S1 ; set axis minima
    M208 X780 Y510 Z350 S0 ; set axis maxima
    M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
    M574 Z1 S2 ; configure Z-probe endstop for low end on Z
    M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
    G31 P500 X390 Y250 Z3.71 ; set Z probe trigger value, offset and trigger height
    M557 X40:780 Y80:510 S100 ; define mesh grid
    M307 H7 A-1 C-1 D-1 ; Disable the 7th Heater to free up PWM channel 5 on the Duex board.
    M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
    M143 H0 S150 ; set temperature limit for heater 0 to 150C
    M305 P1 T4606017 B5848 C5.548428e-8 R4700 H0 L0
    M308 S1 P"e0temp" Y"thermistor" T4606017 B5848 ; configure sensor 1 as thermistor on pin e0temp
    M307 H1 A580.4 C256.6 D6.4 S0.50 ; disable bang-bang mode for heater and set PWM limit
    M143 H1 S493
  • ; homez.g
    ; called to home the Z axis
    G91 ; relative positioning
    G1 H2 Z5 F8000 ; lift Z relative to current position
    G90 ; absolute positioning
    G1 X390 Y250 F8000 ; go to first probe point
    ;G91 ; relative positioning
    ;G1 Z5 F100 ; lift Z relative to current position
    ;G90 ; absolute positioning
  • Moderator
    @chris974M said in BLTouch Zprobe marche pas:
    Your X and Y offset is certainly wrong. This should be the distance from the nozzle to the probe.
    https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Measuring_Probe_X_Y_Offset
    Delete that line. It's not used in RRF3.
    What pin are you connected to? Are you using a duex?
  • Moderator
    What is in your deployprobe.g and retractprobe.g files?
    Does M401 and M402 deploy and retract the probe?
  • duex5 brancher sur PWM5 M401 M402 not work
  • ; deployprobe.g
    ; called to deploy a physical Z probe
    M280 P7 S10 ; deploy BLTouch
  • ; retractprobe.g
    ; called to retract a physical Z probe
    M280 P7 S90 ; retract BLTouch
  • Moderator
    In your deploy and retract macros P7 should be P0 now in RRF3 to match the servo index created with M950 S0.
    M280 P7 S90 > M280 P0 S90
    M280 P7 S10 > M280 P0 S10
  • @Phaedrux said in BLTouch Zprobe marche pas:
    M950 S0
    M950 S0
    M143 H1 S493
  • config.g like that ?
  • before the MAJ my BLtouch work normally
  • ; deployprobe.g
    M280 P0 S10 ; deploy BLTouch
  • ; retractprobe.g
    M280 P0 S90 ; retract BLTouch
  • Moderator
    This was correct.
  • Moderator
    Don't forget to fix this.
  • oui j'ai corriger cette erreur mes sa ne marche toujours pas
  • Moderator
    M950 S0
    This is wrong. It should be M950 S0 C"duex.pwm5"
  • @Phaedrux j'ai corriger toujours rien
    M950 S0 C "duex.pwm5" ; créer la broche servo 0 pour BLTouch
    G31 P500 X0 Y20 Z3.71 ; set Z probe trigger value, offset and trigger height
    M143 H1 S493
  • Moderator
    Try M950 S0 C"!duex.pwm5"
  • @Phaedrux not work
  • G28
    Error: Z probe was not triggered during probing move
    Error: Homing failed
  • Moderator
    Does the BLTouch do a self test on power up with the pin deploying correctly?
    Check your wiring for continuity.
    Are you sure you are connected to Duex5 PWM5?
    Can you try PWM1 instead?
    Yes
    My wiring is perfect
    yesterday i check that before the maj and he is working corrct
