    IR sensor and 2 differen Flexplate system surfaces
    IR Height Sensor
    • caviara
      caviara last edited by
      Good morning/day everyone,
      I know it is a pretty newbie/stupid question, but can someone please point me in a direction on how to do a simple (or not so simple) thing:
      Currently i have a Buildtak Flexplate system with two plates with different surfaces. First one is a Buildtak for general printing and the other one is using "Painters tape" for printing of flexibles and Nylon.
      Is it possible to make some kind of macro that will change Z offset value depending on plate currently in use?
      Printer is using Z-min end-stop for homing and IR sensor is used for bed leveling only.
        Yes, you just need to have that macro set the G30 Z parameter to the trigger height for that build surface.
        • caviara
          Thanks again for the ultra-fast response.
          I thought about it but this will involve calling this macro before every print.
          I was wondering is it possible to make it more permanent - like to change the value for good in config.g/config-overwrite.g from PanelDue (or something like this), until next macro is run?
          • Veti
            Veti last edited by
            you could do it via filement settings
            https://duet3d.dozuki.com/Wiki/Filaments
            create one for like
            pla on buildtrack
            and
            pla on painters tape
            add the settings in the filament config
            and add
            M703
            to your start g code
