    Duet 2 wifi config file for Ultimaker 2 extended
    • Octocom19
      Octocom19 last edited by
      Hi All,
      Do you have a config and json files for the Duet 2 wifi firmware version 3+ for the ultimaker 2 extended please?
      Thanks
      Octocom
        Take a look here: https://github.com/Duet3D/RRF-machine-config-files/pull/6/commits/6995424b445041e9b04eb8bf9fb33d616e768afd
        Unfortunately the pull request for the config set needs some tweaking to be accepted, but the files in there might give you an idea.
        Otherwise, why not just input your hardware details into the config tool?
        https://configtool.reprapfirmware.org/Start
        Octocom19 1 Reply Last reply Reply Quote 0
        • Octocom19
          Octocom19 @Phaedrux last edited by
          @Phaedrux said in Duet 2 wifi config file for Ultimaker 2 extended:
          Thanks for this Phaedrux, the config tool is great I guess I just wanted to make sure I don't make a mistake considering also trying to wrap my head around the fans voltage.
            Well feel free to post your config here to take a look. When doing a fresh config for any printer you'll need to do some careful commissioning regardless to catch any mistakes and fine tune it.
            https://duet3d.dozuki.com/Guide/Ender+3+Pro+and+Duet+Maestro+Guide+Part+3:+Commissioning/39
            • Referenced by  droftarts droftarts
