Homing fails in all axys
  • Good afternon. After powering down my machine, from wich I just had printed 2 calibrations cubes on it, when I powered it up, if fails to home in all axys, wich is stopping me from printing.
    My config.g files is at it goes.
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Oct 10 2020 10:10:05 GMT+0000 (Hora Coordenada Universal)
    M550 P"Hypercube" ; set printer name
    M669 K1 ; select CoreXY mode
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    M569 P0 S0 ; physical drive 0 goes forwards
    M569 P1 S0 ; physical drive 1 goes forwards
    M92 X80.00 Y80.00 Z2560.00 E873.08 ; set steps per mm
    M566 X900.00 Y900.00 Z12.00 E180.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
    M906 X1000 Y1000 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S0 ; Set idle timeout
    M208 X300 Y293 Z300 S0 ; set axis maxima
    M574 X1 Y1 Z1 S1 ; set active high endstops
    M558 P0 H2 F120 T3000 ; disable Z probe but set dive height, probe speed and travel speed
    M557 X15:215 Y15:195 S20 ; define mesh grid
    M305 P0 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 0
    M305 P1 T100000 B4138 R4700 ; set thermistor + ADC parameters for heater 1
    M106 P0 S0 I0 F500 H-1 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
    M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
    The result of the M122 command:
    M122
    RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
    Board ID: 08DGM-956GU-DJMSJ-6J9FG-3SN6R-9UQMF
    Used output buffers: 1 of 24 (8 max)
    Static ram: 25712
    Dynamic ram: 93140 of which 416 recycled
    Exception stack ram used: 272
    Never used ram: 11532
    Tasks: NETWORK(ready,628) HEAT(blocked,1232) MAIN(running,3736) IDLE(ready,160)
    Owned mutexes:
    Last reset 00:01:19 ago, cause: power up
    Last software reset at 2020-10-10 10:27, reason: User, spinning module GCodes, available RAM 11372 bytes (slot 0)
    Error status: 0
    Free file entries: 10
    MCU temperature: min 21.8, current 27.4, max 28.0
    Supply voltage: min 12.3, current 12.4, max 12.5, under voltage events: 0, over voltage events: 0, power good: yes
    Date/time: 2020-10-10 14:13:13
    Cache data hit count 235083728
    Slowest loop: 8.13ms; fastest: 0.06ms
    Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
    === DDARing ===
    Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0
    Segments left: 0
    Movement lock held by null
    http is idle in state(s) 0
    telnet is idle in state(s) 0
    file is idle in state(s) 0
    serial is idle in state(s) 0
    aux is idle in state(s) 0
    daemon is idle in state(s) 0
    queue is idle in state(s) 0
    Code queue is empty.
    === Network ===
    Slowest loop: 15.48ms; fastest: 0.00ms
    HTTP sessions: 1 of 8
    • WiFi -
      Network state is running
      WiFi firmware version 1.23
      WiFi MAC address 5c:cf:7f:76:6d:07
      WiFi Vcc 3.36, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 24232
      WiFi IP address 192.168.1.84
      WiFi signal strength -65dBm, reconnections 0, sleep mode modem
      Socket states: 0 0 0 0 0 0 0 0.
    I've reinstaled everything, with no sucess. I've tried to downgrade to 2.05, also with no sucess.
    I've checked my cabling in order to confirm that there was no loose wires.
    The videos ot this behaviour are the following:
    https://vimeo.com/466872481
    https://vimeo.com/466872441
    https://vimeo.com/466872384
    I'd really appreciate all the help I can get! Thanks a lot!!!
  • It never reachs the endstops, and when I force the home process, it slams against the endstops.
  • @rodolfo_paulo said in Homing fails in all axys:
    Z2560
    Thats an unusual Number for steps/mm, what setup is that?
    you have not set up your thermistors yet. B4138 is the default and not correct for your printer.
    loop up the specs for your thermistor.
  • @rodolfo_paulo
    whats the output?
  • @Veti It is a Hypercube Evolution 2020
  • @rodolfo_paulo You may not moving far enough for the initial movement in the homing files.
    i mean what leadscrew are you using to get that Z2560.
  • @Veti Endstops - X: at min stop, Y: at min stop, Z: at min stop, Z probe: not stopped
  • now press and hold one endstop and post the output again.
  • @Veti M119
    Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: not stopped
    But I do not have a Z probe... Should this be appearing?
    change this line to
    M574 X1 Y1 Z1 S0 ; set active low endstops
  • @Veti , you are a life saver! It worked just fine!!!
    Regarding the leadscrew, I've must have chaged that when I compiled a new instalation in the RRF Config Tool. I'm using an 8mm, step 4 lead screw...
    Is this correct?
  • 8mm 4 start leadscrew with a 1.8 degree motor would be 400
  • @Veti , if you ever stop by Portugal, I'll buy you a crate of beer or wine, which one you prefer!
    Thanks a lot! Now it's calibration time...
    But I still don't understand why did it all go bezerk, with the normal shutdown...
  • i started out with a 2020 hypercube as well, but have converted it to a blv cube since then.
  • @Veti What are the main differences, besides the mgn rail?
  • @rodolfo_paulo
    the parts are sturdier.
    and now all metal parts have been released.
    https://www.blvprojects.com/post/new-metal-kit-upgrade-blv-mgn-cube
  • @Veti Thanks once again!!!
  • @Veti said in Homing fails in all axys:
    @rodolfo_paulo
    I just checked the prices at AliExpress.
    For the kit with the better parts it's more than $900. Then you get to pay more than $500 shipping.
    I'm not used to seeing prices like that out of China.
  • @fcwilt said in Homing fails in all axys:
    it was not designed in china. the stores just offer kits.
    the project site has a bom that you source yourself.
    the kit you are looking at has original hiwin rails
    Yes that much was clear. Still, I've purchased a few kits from China but none as pricey as that.
    Given I have four kits awaiting assembly I don't think the wife would understand why I needed yet another. 😉
  • @fcwilt
    the lite kit is a lot cheaper. it comes without the fancy stuff like led, panels etc.
    @fcwilt
    "Lite Kit" - where would I find that?
    Thanks.
  • @fcwilt
    https://www.aliexpress.com/item/4000374263194.html
    but i would check if you can source the extrusion locally.
    because thats what makes it expensive to ship
